18x9.5 et45 with 275/35-18 Civic Si Coupe
PERRIN_John
Hillsboro, Oregon
altaperformance.com
2017 Civic Si Coupe, Ram 1500 4x4, Sportster Iron 883
I have been struggling on deciding what wheels I want but I have at least decided on the size and offset. Tried a buddies 18x9.5 et45 wheels with 275/35-18 tires and they fit just how I like! No rubbing at all with stock suspension. I will be lowering a little but still don't think it'll rub as that will add some camber at the same time.
Honda Civic 10th gen 18x9.5 et45 with 275/35-18 Civic Si Coupe IMG_3098
Honda Civic 10th gen 18x9.5 et45 with 275/35-18 Civic Si Coupe IMG_3096.JPG
Honda Civic 10th gen 18x9.5 et45 with 275/35-18 Civic Si Coupe IMG_3095.JPG
Nozomi135
Josh
Moncton, NB. Canada
2017 Honda Civic Si (Modern Silver Metallic)
Looking sharp! Almost bought the aegean blue metallic, can't get over how gorgeous it looks!
ebatr24
Oregon
That's a wild size, can't believe those are 275s
MavicTB
Terry
Dallas
18 Civic Si Sedan Aegean Blue
By the way it looks on the bottom picture I say about 2 inches..lol
Hardly. I run 18x9.5 +40 so these wheels stick out 5mm less than mine... and mine stick out less than 5mm. so I would guess this is flush in the front and sunk in a little in the rear. Now after lowering that may change a little. It seems lowering pushes the wheels out a hair more. I cant imagine 275s not rubbing on lowering springs without a but of front fender mods.
X_Gen_Si
Axel
Westchester
2018 civic Si
I was kidding man. It looks good. But you are right tho...
rhino
jacob
Weeb land!
2015 sr5 access cab, 98 civic hx ej7, 2003 KLX400s
What’s the offset I’m interested in doing this on the stock suspension I don’t want to lower my car
