Rough idle, not accelerating
Mortimus
Joseph
Hemet
2017 civic ex-t
I have a 2017 civic ext mt, intercooler, hondata, aem charge pipe and cai. When I start the car up it varies on 750 rpm-+50. When I accelerate it seems to be sputtering and not getting the performance as it did before. I checked the maf sensor and battery reset. I don’t know which hoses to check. I just changed the battery and spark plugs. Can someone help me out thanks
Are you getting any codes?
Mortimus
Joseph
Hemet
2017 civic ex-t
No I’m not at all. I’m gonna try to clean the throttle and see if that works at all
PowerPerLiter
Specific Output
Midwest
Check all couplers and clamps
charleswrivers
Charles
Kingsland, GA
I would check any in the intake path for your replaced parts. Did you compare your plugs vs a chart to see if you were lean/rich? It may not show not having pulled them from WOT (and I sure wouldn't do that now) but it's a data point. W/o s boost gauge to quantify actual pressure it's a bit hard. It sounds like it could be a boost leak.
Mortimus
Joseph
Hemet
2017 civic ex-t
Thank you fixed it. It was a misfire cyl 3 I recently changed my spark plugs like a couple months ago and I just changed em today. Running great again. Thanks again guys for the help
