Stock height.
245/35-20 is 12.25mm (3.7%) taller than OEM. Those tires should make the actual speed is about 4% faster than the speedo read. The spacers are 7075 Aluminum Alloy CNC custom made.How much is Speedo off with that and what spacers are you using.
Where can you purchase the spacers from?245/35-20 is 12.25mm (3.7%) taller than OEM. Those tires should make the actual speed is about 4% faster than the speedo read. The spacers are 7075 Aluminum Alloy CNC custom made.
My spacers are custom made from the local shop (in Indonesia). I gave them a simple technical draw and they made it with CNC machine.Where can you purchase the spacers from?
I was thinking about going with 245 or 255/35/20, whats the purpose of the spacer?245/35-20 is 12.25mm (3.7%) taller than OEM. Those tires should make the actual speed is about 4% faster than the speedo read. The spacers are 7075 Aluminum Alloy CNC custom made.
For aesthetics and make the car heavier to reduce wheel spin during hard launches on the drag strip.... whats the purpose of the spacer?
