KTuner Update: Map Switching Added To Many More ECUs, Non-Si Adv VSA, more to come
David228cx
David
Spain
2017 Red Honda Civic Sport (EU)
Just tested the new options for us european customers (5AAN-G23 iirc).
They are awesome. Advanced vsa rocks...
Thanks @KTuner !!
Any chance there could be a future option to disable start/stop? It's really annoying...
BR
WolfTrax17
Diamond Springs
Can some please explain what Advanced VSA "aggressive" improves for CTV owners? Will it something noticable for daily drivers?
dallasjhawk
Royse City, TX
It improves launching ability just like it would for a 6MT. Mash the gas and the tires spin and factory VSA kicks in, closes the throttle and the car stalls slightly until traction is regained before the throttle reopens. Now, enable Advanced VSA, mash the gas, the tires begin to spin, advanced vsa kicks in, pulls ignition to lower power to the wheels while keeping the throttle open and the car moving forward. You can definitely notice it. CVT user here
WolfTrax17
Diamond Springs
Thanks for explaining it. That sounds awesome! What is the best AVSA setting to use of the three?
dallasjhawk
Royse City, TX
thats up to you. I used the aggressive ignition pullback, and I also press the VSA button in the car to turn it "off" (Its not all the way off, but wont intervene unless severe slip is sensed). I liked the way it felt for me. But try all 3 and see what you like for your setup.
Wolftrax, keep in mind that although the aggressive ignition pullback works fantastic, if you use that too often, it can be damaging to the catalytic converter.
But that really depends on how often you are really aggressive off the line.
David228cx
David
Spain
That leaves a warning on the dash.
As it does if you disable it manually but having to do so every time the car starts is a bit tedious. All Civic X owners I know (Europe) with that function disable it as well.
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
You guys let me know if it's worth it, and I'll add it. Maybe you'll find another way to suppress the dash warning!
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
It's worth it, we just disable it by hand everytime we start the engine, it will show a little orange warning anyway
Honda Civic 10th gen KTuner Update: Map Switching Added To Many More ECUs, Non-Si Adv VSA, more to come citroen-c1-start-stop-off-dashboard-warning-light
kytos
Marcos
Madrid - Spain
Email in your ECU numbers. I have 5AN-E2x and E3x betas ready for testing.
David's and mine ECUs are G23 do you want us to email?. Will forward this to other guys, many of them are E13 ECU's.
David228cx
David
Spain
I think I have a G23, but I'll make sure later today. Yes it would be worth it, even with the warning on the dash. The cool way to have that would be to have it disabled by default and upon pressing the start/stop it turns on.
Okey, send it to us and we'll test it.
Thank you so much for your support @KTuner. I'm sure a lot of people will love this.
Regards,
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
5AW-G32 here, always happy to test things for you :)
amyisquiet
Amy
US
civic fc1
5AF-H13 here, always happy to test things for you :)
