damn that sucks man.Put them on last night...
Guy made a u-turn right in front of me. I cut over to the left lane to avoid rear ending him, but he kept coming and hit me.Ouch, what happened?
For daily driving (non-track), set psi according to placard behind the driver door: 35/33What do you guys run for psi on a 255/35/19?
Bump for an answer for this. I’ll give Titan a call in a bit if no one knows. Thanks.What finish is Techna Bronze? Painted with a clear coat or anodized? Then, are you guys waxing them or using some other car care product after washing them off? Thanks.
You will not rub with that setup.I’m looking to get the tr10s 18x9.5+45. I’m also looking to eliminate the wheel gap by lowering on springs, however I do NOT want to rub whatsoever. Is this possible ? If so what springs / tire size do you recommend ?
Yep! Great setup! No rub!So eibach pro with the 18x9.5+45 265/35/18 is looking good for me then? No rubbing
