Absolutely. I’ve got the “other” cf kind but I can tell you that when I saw a rock chip on the door I immediately put the guards on. Since last year zero chips or dents. And works well by not splashing water on the door keeping the car clean. Anyone running wide tires absolutely needs these.Do these actually work despite being so tiny...?
And thumbs down on that rally crap, looks soooooo bad. Sorry to all those rocking them, looks absolutely hideous.
There is instruction in the packaging.Can anyone post the installation instructions? Anyone have a picture of the fronts installed on top of the fender line yet? Thanks!
Thanks. I just wanted to read before purchasing. I understand no new holes need drilled but sounds like removing a factory rivet or similar. Wanted to see what permanent changes are made to accommodate this before purchase.There is instruction in the packaging.
Yes..using the back the factory holesThanks. I just wanted to read before purchasing. I understand no new holes need drilled but sounds like removing a factory rivet or similar. Wanted to see what permanent changes are made to accommodate this before purchase.
. Here you go brother. I hope to get some time to install mine today. Packaging and quality on the deluxe is very nice I feel for the price they are expensive for plastic but I've also made several custom flaps in the past and material for those cost me a good amount anyway. I like the rounded edges on the deluxe and all the cuts look professional. I also figure the price is justifiable if it beats saving my paint.Can anyone post the installation instructions? Anyone have a picture of the fronts installed on top of the fender line yet? Thanks!
The front's have two factory rivets that are removed during installation and replaced using a different rivet. If you do it properly you shouldn't damage the rivets during installation and the entire thing can be completely reversed. Everything else uses the factory screws.Thanks. I just wanted to read before purchasing. I understand no new holes need drilled but sounds like removing a factory rivet or similar. Wanted to see what permanent changes are made to accommodate this before purchase.
