Adding tweeters to sport
KingMexico
Junior
NYC
2018 sport
Does Anyone have advise on how to go about adding tweeters on the 2018 hatch sport or lx model on the side panel?
Thanks
rjm161
Summerville, SC
'17 Civic Sport Hatchback
You can buy Tweeters that come with a crossover to just hook up to the wires running to the speakers in the door. I replaced all of my speakers.
You'll want to make sure the cups that come with the tweeters fit well. For mine, they required a 2" cutout and they fit perfect. Some of the smaller tweeters wouldn't.
I bought the sail panels for the door from the higher models:
76220-TGG-A11
Garnish Assembly, R Door Mirror (Tweeter)
76270-TGG-A11
Garnish Assembly, L Door Mirror (Tweeter)
Honda Civic 10th gen Adding tweeters to sport W6btqn27c-__B2X6GOZzBsNsHbFNyO2nYGyj8fMbQtqmvs7XcKbgwjQYMMhhYwfJos9DZm5ypQoKV5Zl9a=w1251-h938-no
Honda Civic 10th gen Adding tweeters to sport O4g2K-3MQ7lpgUw1h3GEYk5eEunsVR2J7L9mK-iycmQypQnlz65yvtKqV6ruJTnx5Fmb9V4YDSlzyFgH_d=w1251-h938-no
rjm161
Summerville, SC
You can just use a hole saw to cut the factory panels. Measure them very well...as the door panel overlaps the sail panel. I got my 2017 Sport before parts were available, so I installed them this way until I could get the parts. I feel like they sound better with a bit of angle toward you, but that might just be in my mind.
Honda Civic 10th gen Adding tweeters to sport BzbbNfsa_JblBliUcl8_50xNzx4G0UWzrfuEnc0Iqx9hXi86cYvsKWNNqfrJF1u4m5ur9NcGtRKmfZPVNP=w1251-h938-no
jcivics
Manchester, New Hampshire
2019 Honda Civic Hatchback Sport
And if you have rear passengers you care about. :)
6v2k0f9zHRQVmvbpMfFbMYRFyWPabgn8zh_xmyXqbirjrcLFxEkqch0cf4cmExHKgdgkM_Qb9SoYXmCOe0=w1251-h938-no.jpg
I like that a lot. I had 2-ways in the back it sounded like ****!!! Put in the components and so much better. Can’t wait till it’s amped!
Also on the backside of the panel there’s actually a stencil mark in the plastic. My components were 2” so it worked great. But yeah good looks on that, looks great sounds great
tsixtial
So.Cal
2019 Honda Civic LX
Sorry to bump an old post would these sails fit 2019 Civic 4 Door?
rjm161
Summerville, SC
I would assume so but you should be able to just go to any of those parts places and look at the diagrams for the four-door EX and above, or whatever has tweeters from the factory.
tsixtial
So.Cal
2019 Honda Civic LX
I was trying to look at those diagrams online and it’s freakin confusing :(
RaoulDuke
Zach
St. Louis MO
17 civic sport cvt
Digging up old thread, does any know if coupe si oem front tweeters will fit a hatchback sport front door?
Zavage
Germany
Civic EJ6, FC1, Accord CU1
Do you mean the tweeters by itself or the triangle piece where the tweeters sit in?
