PowerPerLiter
Specific Output
Id be willing to wager money that if we had a little crystal ball about what caused this, it would be a slightly bent rod from the dyno pulls. Have you ever even data-logged the car with this "stage2" tune? Probably not monitored on the dyno either.
Was the maf signal tuned for the aftermarket intake?
These are not "play things"
You cannot just modify a car and put one of the max power "canned" tunes on a turbo engine thats running 23+ pounds of boost on a 1.5l and not be careful with the dam thing.
It saddens me your dealing with this if your as innocent as you say about it.
The load the dyno certainly put through the car and computer was probably something it hadn't seen anything like before and trust me that load never let up during the pull. Do that again 3 times in a row....poor car.
Just to exemplify this imagine you put a trailer on the car hauling ,lets say for the sake of conversation, 1000lbs behind you....let the car slow down to 2100rpm (in fourth gear even because thats the dyno gear most of the time)....floor it and let it struggle until rev limit....with little to no real airflow....then do it again....then do it once more.
They usually go wot very low in the rev range and the power your car didnt make was probably because knock control was through the ceiling. Clearly we will never know but that dyno episode is the striking difference between all of our cars still running with miles upon miles of monitored tuning (23k myself currently) and yours with a premature death; where the roughest day of its life was that dyno day.
Dynos are only good for heartbreak and engine carnage if they aren't being used as a tool. (And even sometimes when they are...)
