Stock Type R tires only last 9,000 miles?
MonkeyBoost
Saint Petersburg, FL
2017 Type R #680 CW, 2011 Mazdaspeed 3
Honda even warns about it right on the window sticker.
Honda Civic 10th gen Stock Type R tires only last 9,000 miles? TIRES
ez12a
CA
18 CW Type R
They beat the crap out of them. Pushing 20k here on my original tires. Got a set of take-offs from other members ready to go.
Gansan
Glen
San Diego, CA
1999 NSX, 2018 Civic Type R
I'm almost at 15,000 miles and that includes 2 days at the track. I rotated the tires right after the track days because the fronts were worn quite a bit, and now I'm expecting to get close to 20K miles. Or until the next track weekend destroys them.
bi9guns
Dallas
R35, Sienna
I rotated mine 6K miles and was advised to come in after another 4k miles for early rotation. Good thing I did because steel belts were showing. Zero track days.... Switched to Toyo Tire
Proxes 4 Plus 255 /30 R20 92W XL BSW all seasons rated for 50K miles. Discount tire will prorate if tires wear prematurely.
Gansan
Glen
San Diego, CA
I bet the local roads we drive on matters a lot also. Fresh, smooth pavement is a lot less wearing on tires than old, rough pavement. The worst is the surface when they scrape away the top layer in preparation for laying down new asphalt.
willskiGT
Atlanta
2019 Civic Type R #26262
I find it interesting that so many people switch to all seasons after the stock Contis are gone.
What's the motivation behind buying a high performance car and then putting on tires that greatly reduce performance? Swapping to winter tires when it's cold is one thing, but why all seasons?
frontlinegeek
Jason
New Brunswick, Canada
Those tires are only 240 UTQG with an AA A grip rating. That is a guarantee for fast wear if you push them a lot. That class of tire should just not be expected to last super long. Not at all sure why C&D made such a deal out of it.
tinyman392
Marcus
'18 Civic Type R (RR)
Do I push the car hard enough to reach optimal operating temperatures? Do I push the car enough to justify getting dedicated high performance summer tires? Do I live in a region where it's always 90+ degrees out to be in an optimal temperature range to use the tires?
My previous set of all-season tires (Nitto NeoGen) were optimal between 60-80 F, good from 35-100 F (don't have many 100+ days), OK -5-35 though they worked fine all the way down to -30. Note this is dry road (salted if it's below freezing). Our roads are normally salted and cleared within 24 hours so driving on light snow is the worst that it gets and 99% of the time the road is clear with a dusting of salt. My current set are the Michelin PS A/S 3+ which I have only had for a week, so no info on that.
When I had the stock Continentals, they seemed best from 80-100, good from 60-80, then OK from 40-60. I tried to not use them below 40 F for obvious reasons. The Nittos actually felt like they might have more traction than the Contis around 70 F, 80 F felt like a wash. This is from memory.
In the Chicagoland area, I'd estimate that we get around 90-degree weather (80-100) around 60-90 days out of the year. Then the 40-80 F range probably close to 180 days out of the year. Lately (4 years), we've seen 14-21 days of -10 or below, then regular winter weather for the rest (-10 to 40-ish degrees). The kicker this year was the fact that we had 2-3 winters (depending on how you count them). The first was typical starting late December to about mid March when the weather hit around a constant 40-50 degrees. Most people put on their summer setup early or mid April when we began seeing highs of 40-60, I felt sorry for them. Mid April saw the coming of a snow storm producing about 6 inches of snow with temperatures dropping around 20's. Lasted about 5 days before temperatures rebounded back into the 60's. 5 days later and we get another snow storm producing temps around 25-30 with another 6 inches. Our May was what we normally got in April with a lot of 40-degree weather. This sort of weather isn't commonplace, but it happens enough to throw people off.
On top of that, I'm not tracking the car or using it on a drag stip. The all season provide more than enough traction that I need for the spirited runs I do and my DD. They also tend to have better tread life as well (not always, but typically do).
Note these temperatures are air temperatures without accounting for wind chill or humidity. In a location where the temperature is 70-80+ for 75% of the year, definitely go get some dedicated summer tires as they're most likely in their optimal point for traction. I don't get that here the all-season seem to be a better fit.
TL;DR: All season are optimal 50% of the year for me while summer tires are 15-25%. At their optimal range, I felt like the all-season provided slightly more grip than the summer (at lower temps) or about equal (at higher temps). Weather is completely unpredictable were I am sprouting snow storms in between 60-degree weather in Spring (anyone on a 2-tire setup was kind of fucked over by April). The all-season simply seems like the better tire of choice for my DD. If I were to do a 2-tire setup, I probably would still opt for the all-season tires during spring-fall and use a dedicated winter tire for the winter. For a warmer climate I understand the use of a dedicated summer tire for spring-fall as you're typically always in the optimal traction temps, for cooler climates, like in the midwest, I understand (and use) the all-season tire.
___
I will make one more comment regarding the April mishap that happened this year. I know a lot of people swapped winter tires back as the second snow storm hit. It's August now and I still see people with Blizzak's on their cars for whatever reason (maybe they were too lazy to swap them back?).
Zeffy94
Matt
Doylestown, PA
The new C8 comes with all seasons standard; there’s a good article from Car&Driver on it too, but the gist of it is that the UHP A/S tires are actually closer to some of the summer tires in handling performance than many think. Do they provide the same levels of grip? No, of course not. However, for most people who do not track their car or push it to 11/10 every day, the difference in grip will not be noticeable.
When I had my DWS 06 on I could still take corners much faster than most could without hearing the tires squeal. The only problem with those tires was off the line it was a bit more wheel spin than usual, but otherwise they worked great. Not to mention the fact that if the temperature dipped sharply they would not make me feel like I was on ice.
There’s no point running a winter tire for me because where I live snow isn’t uncommon but it’s not frequent ether during the winter. However, the temperatures have a range and I found that the all seasons did what I need them to do during those months while still giving me good performance.
Nothing wrong with running all seasons on this car, especially because the performance delta off the track isn’t as large as many think it is.
eshults5
Eugene C Shults
Lansdale PA
2018 Civic Type R
I'm at 11k miles and still using the stock summers, but was running all seasons for most of those miles during winter.
Since I have to switch to winters or all seasons over the season, the summers can really last you like 2 years. You need 2 sets of tires if you live in most areas of the US unless you're ok with the reduced performance of having all seasons all year long.
eshults5
Eugene C Shults
Lansdale PA
2018 Civic Type R
I run the same tires. Little less handling but what really is noticeable is that 1st gear wheel spin, for sure. Although that could also be the colder weather.
djhartm
Dave
Raleigh
2019 Civic Type-R
Shit, mine fell apart after 1.5 track events at VIR with <1800 miles on them.
Conti replaced them, and by running very high pressure and rotating them halfway through events, they are doing better, but I doubt I'll see 4k and 4 events out of them.
FK8_8220
Kevin
Belgium
Civic Type R FK8
mine have 10k on them and look like they'll last at least 5 more, the rears look like theyve hardly worn at all. I daily drive my FK8 so its a pix of spirited driving and normal driving.
I dont do hard launches though
MediaMaster
Mark
Frozen Tundra
2020 CTR, 2024 Ford Maverick
___
Thanks Tinyman392. I live in Green Bay another 300 miles north of you and have similar plans for my new 2020 when it arrives. I will be purchasing a set of 19" wheels and I'm still trying to figure out whether I will go with 255/35/19 or 245/ 35. Looks like the Michelin PS A/S 3+ are the A/S tires that most CRT owners like the best. Now that you've had them for more than a week are they still meeting your expectations?
I was thinking about how long I would be able to use the summer tires up here and I think most of June, all of July and August and at least this year all of September (but normally the first half of the month.) The first week of Oct. looks like it will have highs in the 40s/50s and probably a freeze (finally will get rid of the f-king mosquitoes). So I will save the summers, mounted and ready to go, and use the 19s for the remainder of the year. Will probably try at least one session at the track (Elkart Lake) if they allow.
Weather here is very unpredictable. I've seen lows around 32 in June and Sept., highs in the 90s in May and Sept. and lots in between. I have actually played golf in every calendar month - go figure.
tinyman392
Marcus
I haven't had anything close to freezing yet, so can't really comment on cold weather use (but am planning on trying them out). That said, as a spring/fall/summer tire so far I've been very happy with how they've performed. They don't offer as much grip as the OE tires, but still offer more than enough for spirited street driving. The other tire to consider, which is also very popular are the Conti DWS06.
