TypeRLEDs
#1 Source for 10thgen LEDs
- Mar 13, 2018
- 16
- 626
- 391
- Houston TX
- Website
- TypeRLEDs.com
- 2017 Honda Civic Type R
- Vehicle Showcase
- 1
- #166
Thanks for the question.Do i need to add a resistor on a brake bulb, rear signal bulb and front signal bulb?
You do not need to add resistors for the brake LEDs.
If you are installing Front and Rear turn signals, you will have to install 1 set of Resistors in the front or rear.
If you are running only 1 set of LED turn signals you do not need to install resistors.
Thanks!
