Naruske
you need to see what the CEL is ... the rev match error is a thing that pops up everytime a CEL pops up.Even after disconnecting and reconnecting battery i am still receiving CEL and rev match error. Could this be the culprit? I tried my best to put this as up as i could but maybe it needs to be all the way in?
It is not supposed to be all the way in. Did you accidentally touch the MAF sensor when you install the intake? I didn’t disconnect the battery either and never had any issues.Even after disconnecting and reconnecting battery i am still receiving CEL and rev match error. Could this be the culprit? I tried my best to put this as up as i could but maybe it needs to be all the way in?
Only thing you touch that can maybe trigger a cel during an intake install would be the maf sensor really.
I have not idea what it was but i tightened all the clamps again and blew some air on the maf sensor both ways then fired up the car and didnt get any errors. Honestly i think the maf sensor had something in it... so yea. Everything is working perfect!! Also the WOOOOSH is every boys wet dream. I did some pulls and will upload to see if my dashcam catches the noise! But thank you guys for all the help!!!It is not supposed to be all the way in. Did you accidentally touch the MAF sensor when you install the intake? I didn’t disconnect the battery either and never had any issues.
Do you have any rubbing issue with the evap flange? I see that you rotate it, but that also rotate the hose upward, and it may rub against the hood.
drive it. should turn off right away.My install went perfectly fine. I have no rubbing issues or anything like that. My only question is how long do I have to wait for this warning to go away?
Any pix? I want to see how yours is different than mine.My install went perfectly fine. I have no rubbing issues or anything like that. My only question is how long do I have to wait for this warning to go away?
