A guide to smooth shifting for your Si, Sports, or other Civic manual
amirza786
amirza786
A
Northern California
Nice writeup! I am curious if you tried the throttle padding options on the KTuner after disabling Rev Hang? Did you still not like the driving experience after trying the padding options? Thanks!
No I didn't, but that being said, Rev hang doesn't bother me at all, I got used to it and now actually like it
Tags
2020 Audi A3 Quattro, 2020 Volkswagen Tiguan
In my experience so far, the single greatest factor is temperature. I have Amsoil, but 1-2 on a chilly morning is always dicey (chilly here being 50-60 degrees) no matter what the technique, whereas after a half hour on the freeway, or even heading to lunch after the car has been baking in 80-90 degree temps for a few hours, that shift is much more solid and stress-free, even if rushed.
For those morning shifts I also notice a little better engagement if I work the lever from neutral into second a couple of times while stationary (eg, at a red light) before selecting first and accelerating.
Agree that the little pause in neutral helps, but it's a very subtle technique. Too long a pause by even a split second and Yarises and bicyclists start to pass you. A little too much premature pressure on the shifter waiting for the synchros to line up and suck the lever from neutral into second and you can get some ugly-sounding scratch. (This is one reason why, for now, I've gone back to the light stock knob after trying some heavy ones. The heavy knobs carry more momentum from 1-2 and sometimes interfere with that pause.)
Fast and decisive clutch footwork also seems to help a little. Get lazy with the left foot and (because of the CDV?) the synchros have more work to do and thus need more time.
I know the theory that says rev hang makes no difference, but subjectively it sure seems like eliminating it in favor of medium throttle padding has made life a little easier for the synchros, too.
I'd like to get the Acuity rocker, but I'm also wondering about the CTR shifter, since it makes sense to do them together. Anybody have experience with it beyond the couple of posts out there?
All of this, of course, underscores what a weak spot the Si shifter is -- dating back a long while, and for other Hondas too. Just mindblowing that with all of Honda's engineering resources they can't just make a consistently solid-feeling, long-term-reliable manual shifter.
amirza786
amirza786
A
Northern California
A cold manual transmission is always clunky, any car. Once it warms, which is usually a few blocks it should be fine
FLOPPER
Thomas
DFW
2017 Civic LX 6MT
Get it, shifting is a pleasure after installing the CTR shifter with all of the Acuity upgrades.
I got everything in the Stage 2 Bundle for FK8, except for the cable bushing. The rocker, centering spring, and CTR shifter itself are probably the biggest upgrades. The bushings are nice but probably don't contribute much to the whole upgrade.
I installed the cable bushing at a later date and to be honest, didn't feel a difference.
If you have to prioritize, I'd go CTR shifter, rocker, centering spring, then base and cable bushings.
COOL COUPE
South Carolina
I have had some good luck "blipping" the throttle between shifts. Almost like rev match ...it definitely defies logic. I was born in 1966 so the rev hang is a nasty problem due to my classic training in shifting a manual transmission. Think of steps ... Instead of grabbing second gear at a Lower rpm ( wait wait wait wait for rev hang to disipate) blip the throttle up and grab second at a HIGHER rpm than where you left off! It's like the moonwalk ... It's totally an illusion. Grab third up higher than second. Once you get into fourth you can level it out a bit ...
lhobbs
Luke
VA
2018 Civic Si Coupe
I'm much more inexperienced with driving MT but have issues shifting smoothly occasionally--can you explain this further? Is this different than NOT waiting for the rev hang to dissipate and shifting while the revs are already high?
COOL COUPE
South Carolina
Best advice is to ... Not think and ... Just push the throttle a tad ... and shift ... You will get the feel for it quickly. Reminds me of the movie blind fold or whatever with Sandra Bullick. Just like the moon walk it's totally not conventional. Best explanation is that revving up to say 5000 rpms in first gear causes the rev hang big time ... Pushing ever so softly on the throttle as a rev match interrupts the process and allows a quick move avoiding wait wait wait wait for rev hang to dissipate out.
Cornercarver
Paul
Rio Verde AZ
2018 Honda civic Type R, 2002 Lexus SC430
I thought I would write this up seeing as there are a lot of posts on people having issues with 1st to 2nd gear shifts, as well as 3rd to 4th. Many are complaining that is not smooth, crunchy, and some are even experiencing gear lockout. Before I get into how to deal with these issues, just some background on myself.
I am 51 years old, and drove nothing but manuals throughout the 80's and part of the 90"s. I learned on a VW Dasher, moved on to two VW Rabbits and a GTi, drove my dad's VW Vanagon occasionally (4 speed manual). Finally being sick of the mechanical issues of VW, in 1995 I bought my first Toyota, a 5 speed Corolla LE and never experienced mechanical issues since. I got married in 97 and in 99 I bought a Camry and left the world of MT behind, (the wife can't drive manual), owning 6 trouble free Toyotas until 2018, when I bought my first Honda. So there you go.
Now before I move on, there are a few things I would recommend, in fact in my humble opinion at least one of these items is pretty much mandatory:
Change out that junk OEM MT fluid for Amsoil Synchromesh. I have a pretty extensive thread on this so I won't go into to much detail. I will just briefly mention that it not only smooths out shifting, helps with the 2nd gear lockout, but makes this transmission smooth, the way it should be, and makes this car pleasurable to drive
Invest in an Acuity Shifter Rocker Upgrade. It basically replaces the OEM plastic shifter rocker with an machined aluminum shift rocker, making the shift gates tighter and closer together. It does not eliminate the notchiness, but makes overall shifting smoother, brings the gears closer together and will last much longer than the plastic rocker Honda installed. At $70 it's an inexpensive upgrade, of course you will have to tear apart your center console to install, so if you want to install any other acuity upgrades, this would be the time to do it
Now that I got these prerequisites out of the way, let's move on. First of all I want to mention that although I have the TSP Stage 1 tune, I do have Rev hang enabled. With Rev hang disabled I felt the car was way to jerky between shifts, as the RPM drop is to rapid. In my opinion, it drives way better with Rev hang enabled. Also, Rev hang does not interfere with shifting, it is more of a mental block that causes people to delay the shift which leads to messed up shifting, but once you get over this, you will find that you can shift at any RPM with no problems.
The first thing we have to realize about this car is that it has a synchronizer. I don't want to get into technical details about this, but in a nutshell it lines up the gears properly so they don't grind. If we do not allow the synchronizers the chance to line up the gears, that is where we get the grinds and gear locks. It will take some practice, but if you shift properly, you can do so at any RPM, even near redline. The best way to shift from 1st to 2nd is to give about a .2 to .5 second delay before going into gear. Don't yank the gears from 1st to 2nd, but more pull it into neutral, give it the .2 second delay, than shift into second. This works well even when "power shifting". It is really hard to explain, I might post a video on it, which would probably demonstrate this much better.
This technique also works shifting from 3rd to 4th and 5th to 6th. Another thing I find very helpful is shifting after 3000 rpm (I usually shift around 3500 or so). For those worried about fuel economy, as long as you are not going into to boost, fuel economy is not really affected. I have been able to maintain an average of about 27 mpg street driving. By doing this you are able to keep everything smooth and maintain the powerband, and prevent engine lugging, which actually puts a lot of strain on our engines.
One thing I can tell you, by following the above advice, your shifts will be smooth, you will experience much less notchiness and grindings and gear lockouts will disappear, and you will enjoy what this car actually has to offer. If anyone else has any advice they would like to share, please feel free to weigh in
You are correct of course. I noticed early on if I took a beat in neutral before putting it in the next gear it went way more smoothly than if I tried to go from one gear to another without that fractional pause. it actually saves you time on the shift since it goes in to the next gear smoothly.
Haven't done the Amsoil or Acuity kit, but also haven't had much issue shifting. As I have owned and driven numerous manual cars over the last 44 years, it is about being in tune with your car, not forcing it to do your will. Every clutch and shift mechanism, let alone the engine, is different.
One technique does not work for all manuals. Some cars - very few - were actually designed for you to slam the gears because they inew their buyers would speed shift. I am thinking of some early American muscle cars.
yyalb
Albert
Michigan
10 gen Civic Si
I just changed the MTF at 29k, but Honda OEM fluid. The shifting feel has not improve much, and the nochiness is still there. I'm tempted to try Amsoil synchromesh, but the viscosity is different from what the user manual suggests. Please mind that the MTF is not only for trans, but also the LSD. I'm afraid that the Amsoil may cause excessive wear on the LSD.
firesyde424
US
2020 Civic SI
I’ve had my Si since April, it only has 2500 miles on it and I don’t even notice the rev hang any more. I drive it normally and I shift slow. Not really slow, but I don’t shift fast. It might actually take 1-2 seconds to shift. I have no grinding, no notchyness (not even a word lol), no nothing, just a smooth shift. I believe to many people think they’re driving a race car and it’s not performing like they think it should.
I am going to disagree on your shifter comment. Coming from a 2003 manual to a 2019 manual, the shifting is very short. Adding something to shorten it up further will just create problems for people who aren’t as experienced as some of us. When I first got this car, even I was having issues going from 5th to 6th gear. I was coming back down to 4th. So by adding an even shorter throw, I’m sure people could accidentally go from 3rd to 2nd instead of 4th. There are many videos with people racing with this happening. Even going from 2nd back to 1st.
This was my experience as well. I've had my SI about 5 months with 4,600 miles on it. My previous cars were an '06 Sentra, '97 200SX, '91 Grand Prix, and an '84 GTI. It took quite a while to get used to the difference in clutch feel and rev hang but once I did, I found it to be the best manual transmission I've used over the years.
Neps18Si
P-Low
Davie, FL
2018 Civic Si sedan (sold), 2019 Civic Sport Hatch CVT
And finished with the Type R shifter and other Acuity goodies shifting gears is so much better.
Honda Civic 10th gen A guide to smooth shifting for your Si, Sports, or other Civic manual 78FDC87C-3191-415B-8053-5ECB2FC8CB25
Honda Civic 10th gen A guide to smooth shifting for your Si, Sports, or other Civic manual 47F54DC6-9FB9-46EE-AFF7-243632A3332B
James3spearchucker
El Paso, Texas
To do list:
1. Get it out of your head that everything Honda is 24k gold. It isn't!
2. Especially when shopping lubricants, look at the actual viscosity numbers and base stock formulas.
Everyone here has had good results with Amsoil. Thats great. I have had good results with Motul 300V 75-90. I do not have an LSD but the Motul has the friction modifiers for one. The Honda fluid was thin and did not let me feel and know where I was. Now, there is a thicker film on the metal parts and I can feel what is happening. When people get shifted(no pun intended) from the older rod linkages to the new cable types, you lose a lot of your feel and precision. Now, I have more feel and protection. I have not had a single grind or miss-shift like before. The trade-off is time, as things are slightly slower now. There is a Joe Gibbs Racing Driven gear oil that is 70-80(thinner) and I had wanted to try at some point, but I like what I have now. I'm not drag-racing my Civic. I simply want it to last forever and shift great each time. In the future I plan on reducing the rev hang and clutch delay because they take away valuable seconds of my life!!
The Acuity rocker and spring were explained to me by the fine people there but since changing out the Honda fluid, I can feel where the shifter is and the protection for shifting has been superb. I could still use the spring for spirited driving, when my body is moving around, but it's on the back-burner for now. Also, on driving the SI Civic on test drive once, I felt its shifter is shorter and more accurate than the HB Sport.
Ron R
Northern California
2018 Honda Civic SI Sedan
That is a great write up and on future interior mod list. I do like the factory shifter, and the feel of it. But I am curious if it will smooth out my shifting.
The family and I just got back from Monterey few days ago. On the ride home my little 6 year got nauseated. The wife said it could have been from my shifting? She had the same issue when she was little, and her parents had the manual Datsun 510.
I have no problems with the shifter, but like taking the SI on family trips. And the wifey can drive stick shift too. Just wondering if the mods will smooth out the shifting?? Yes driving skills matter, but I know I can get bit sloppy if exhausted lol.
amirza786
amirza786
A
Northern California
For sure the Amsoil Synchromesh will really make things smooth. The Acuity shifter Rocker upgrade is an added benefit making the shifter tighter
