makanouchi
- Lac
- Oct 31, 2017
- 18
- 94
- 94
- Austin,TX
- 2017 Civic Type R
Possible to add tire pressure to tunerview?
These vehicles do not have tire pressure sensors. You get a tired pressure warning when one tire is spinning faster or slower than the others as calibrated.Possible to add tire pressure to tunerview?
It's not.Maybe it's clarified somewhere and I missed it. How come map switching is disabled under something like 15mph?
I agree. I'll see if I'm able to replicate in the near future to give you a definitive answer to them ignoring. You may want to try just holding it longer and see if that works.Ok. I moved where I mounted the v2 so eventually it will find a new permanent home and not be an issue it's just been annoying while I'm not running it in the car since I have to switch back every time I start the car. Weird that it doesn't ignore those buttons while stopped and the clutch is pressed though.
Did you just send me an over the air update? lolI agree. I'll see if I'm able to replicate in the near future to give you a definitive answer to them ignoring. You may want to try just holding it longer and see if that works.
