PRL Cobra CAI Race Tuning
raynist
Ray
Pittsburgh
2018 Cosmic Blue Civic EX-T Manual
Any updates?
I ordered and received the race intake but will not be able to install until after the new year.
aaron.fc3
Aaron Paul
2018 Honda Civic Si Coupe
Installed everything the base map for the race intake is perfect! This thing rips now!!! Thanks guys!
After installing the race maf, which base map did you use? Got emission lights on atm
AREA
Houston, TX
18 Civic SI coupe
contact K-tuner they will provide it for you at no charge! However I suggest purchasing TSP stage 1 tune for the race MAF for full gains.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
The RACE MAF option is under Main Parameters>MAF Scaling for all Civic 1.5T models.
highroller
U Hash
Pak / NY
Civic 1.5 Turbo
After selecting race maf from drop down menu I saw a change. Can you tell whether its normal or needs attention?
Before MAP reading was 979 now it is 282.
Thanks
kimtyson
Kim
York, Pa
2020 Blue Civic Si Coupe
@KTuner Sorry if asked already. I am multitasking. I have a TSP file that I am currently using on my OEM stock setup. I want to confirm that I can use the same file for a new PRL race MAF SRI. It's just a drop down menu change to race MAF or something? Is that correct? Or do I need an entirely new tune file from TSP for race MAF? Thanks!
You will not be able to do that on your own unfortunately but TSP has a program in place to assist with such a task.
highroller
U Hash
Pak / NY
Civic 1.5 Turbo
You'll have to ask tsp for a revision since the tune is locked and you won't be able to access the dropdown menu where you select your intake.
