PdaNet+ free hot-spot!
himynameisaaron
Aaron
PA
2018 Pearl White Honda Civic SI Coupe
Hey guys. So I was trying to figure out how to use my phone as a hotspot without having to pay the carrier hotspot fees. I stumbled upon an app called PdaNet+. It works like a charm. It allows you to use various methods (USB, Wi-Fi, Bluetooth) to use your phone as a hotspot for free! Works on my laptop. So I was messing around in the car and thought maybe I could g et it to work on the head unit. Now this DOES require Honda Hack. Search for PdaNet APK download. Put it on a sd card, plug it in and use Honda Hack to install it. It's compatible with the version of android on my 18 Si. End results? Works like a champ. To use it, on phone select "Wi-Fi Direct Hotspot". Once you do that, open pdanet on the head unit and select "PdaNet Hotspot". You'll see on the screenshots there is a blue area at the top on the phone app showing you the password. Enter it and viola. Free Hotspot!
Honda Civic 10th gen PdaNet+ free hot-spot! IMG_20190701_154212024
Honda Civic 10th gen PdaNet+ free hot-spot! IMG_20190701_154131547
Honda Civic 10th gen PdaNet+ free hot-spot! IMG_20190701_154312258
rplush
NY
2016 Civic EX
This is definitely an option but your carrier knows whether you're using your data for the device it's intended for or if its being shared to another device. PDANet+ was a hotspot solution in the iPhone jailbreak scene back in the day when carriers only offered hotspot as an additional paid feature. Those who were grandfathered in for unlimited data had no access to hotspot feature. Unfortunately there were numerous reports of the people who used PDANet on a JB'ed iPhone got kicked off their grandfathered unlimited plan
Triple_peaz
Brother Taresa
Brandon
Louisiana
2019 Honda civic si sedan, 2016 Honda pilot
Shit, I'll give it a try thanks bro
dc2turbo
usa
civic,teg
if you link up honda link with your phone. it iwll give it internet
dc2turbo
usa
civic,teg
download the app Honda link on your phone and have bluethooth connection to the headunit...
Triple_peaz
Brother Taresa
Brandon
Louisiana
I got it. Drove away from the house to make sure it still wasn't linked to my home wifi. Had YouTube on and it was playing fine. Thanks for the post bro
Micah
Toms River, NJ
Pdanet is oooooold. I used it on my palm Treo 650 back in the day, then later on my iPhone 3GS and HTC Mogul. It was a way to have unrestricted internet browsing while at work. Would pop the ethernet, plug in the USB and use the usb modem connection. As an IT geek it worked well enough but would have been kludgy for a normal user. They (pdanet) play a cat and mouse game with carriers. Measure vs counter measure.
Eventually your carrier will notice an increase in traffic. Most carriers plans offer hotspot. I know Verizon does. I use between 30-60GB per month, about a third of that is tethering.
Triple_peaz
Brother Taresa
Brandon
Louisiana
I haven't really used it much just for the initial test. Not sure when I will ever need to use it.
