What did you do to your Type R today?
Andjoo
Vancouver, BC
2018 Civic Type R - CW #19431
This just drops into the factory sub hole? You got a link?
https://www.ebay.com/itm/MB-Quart-D...rentrq:762d3e9616b0ad31c3a63c35ffc03232|iid:1
This is the sub I bought.
Unfortunately, it wasn't a complete drop in. The sub holes didn't line up with the factory holes :-( . So I drilled holes into my factory enclosure, and sealed off the factory holes. Otherwise, the install was straight forward and I followed the step by step detailed by ctrmofo (with the polyfil, and all the goodness).
ExVTEC
Elliot
2019 CTR
Did you just swap the sub speaker or did you do the additional amp?
https://www.ebay.com/itm/MB-Quart-DS1-204-8-Shallow-Mount-Car-Truck-Subwoofer-w-Poly-Cone-2-Voice-Coil/351449146965?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=620c59958f88460f90126f0a7054ef0f&pid=100675&rk=3&rkt=15&mehot=pp&sd=173853633951&itm=351449146965&_trksid=p2481888.c100675.m4236&_trkparms=pageci:5ae68f89-938a-11e9-85c8-74dbd18070f7|parentrq:762d3e9616b0ad31c3a63c35ffc03232|iid:1
Andjoo
Vancouver, BC
Just swapped the sub. For me, this is more than enough. My bass is much thumpier now, adding a dedicated amp would be overkill. Even testing it out in my garage created enough wife aggro...
r712
FL
2017 Civic Type R (FK8) | 2017 Fit (GK5)
Got the ZL1 Addons mudguards installed today. Install took about 20 mins tops. Definitely like how minimal they look compared to the rally armor ones.
Honda Civic 10th gen What did you do to your Type R today? 2019-06-20 06.03.05 1
Honda Civic 10th gen What did you do to your Type R today? 2019-06-20 06.03.06 1
markq218
FL
2010 Scion tC, 2019 PMM CTR
These look great! Is this the deluxe or the standard one? I see the deluxe is 85 and standard is 50... not sure if its worth the 35 difference
ChampwhiteFK8
Daniel
Oceanside, CA
'19 CW Type R
According to them it's supposed to be better texture and material. Last I checked deluxed aren't going to be released until sometime in Aug.
r712
FL
They're the standard ones.
ExVTEC
Elliot
2019 CTR
Maybe check these guys out.
https://www.colorxlabs.com/
They have matching color wrap
Going stealth mode to avoid unwanted attention. Plugged the holes with white Gorilla tape. May plasti-dip over it if it collects too much dusts.
I'm going stealth mode to make it look like a regular hatch to draw less attention. Wing is permanently removed for now. I've removed the front and back R badges because I don't want people to steal them. The rear H was covered up for the same reason so I plasti-dipped it instead of removing it by breaking the pegs.
The final stage will involve pin-striping (black) over the red on the wheels and aero package. Did one wheel already.
nickjohn35
Cincinnati
Current: 2017 PMM Typer R. Former: 2004 350Z
Could you post a few more pics at different angles please?
