- Mar 21, 2018
- 43
- 1,778
- 2,433
- planet earth
- '13 lambo lp550-2, '18 honda ctr cw (r-12321), 14' porsche cayman s, '16 porsche macan s, '13 mini jcw nme stage 1, '15 audi s3 apr stage 2, '15 audi q3, '12 monster 1100 evo, '16 triumph thruxton r, deposited for '19 lambo huracan performante
- Vehicle Showcase
- 2
- Banned
- #16
hu app and tune has nothing to do with each other. it's the bluetooth connection.I do have Honda hack pro. I'll be home from work within the hour and will give it a go. Hope it'll go smoothly now that I have your detailed instructions. Will report back.
Update: Tune went smooth, but the bt/Hondata app worked 50% of the time. When it doesn’t, I get the repeated connection failed/retrying message. I got it to work and then did the tune, but now it’s failing to connect. Should I have done the tune first, then the app, or does it even matter? I uninstalled the app again and re-installed, but couldn’t get it to work until I cycled the ignition 4-5 times. It’s worked consistently for 2 drives now. We’ll see if it continues to..in any case, I owe you!
what else do you have connected to the hu via bt? it's the hu that's problematic actually and finnicky with bt connections.
