Yeah, you email him what your wanting and he sends you a invoice thru PayPal.He just says email him in the YouTube video.
NopeDo you know if anyone has opened one of these to see what’s inside?
I just looked and I payed $80 total for both.The guy seems to be very secretive with where he gets his resisters and parts. Makes sense if he wants to monopolize oh this very specific business..
I've read many conflicting results with using the standard solution of 50W 6ohm resisters in parallel with the new LED lights. In one of this dude's videos, he shows how this solution can cause the resister to get up to 400 deg F after some time of usage whereas his harness only goes up to 150 deg F.
I'm wondering if he uses different resisters, configuration, resistance wattage or some other black magic in his box. The fact that he says it would fix the hyper flash issue on both front and rear lights with one harness leads me to believe he might have some more insider knowledge of the harness's wire diagram.
One tip from iJDMtoy with the simple 50W 6ohm load resister solution is to not use T-taps or quick taps because it may not make a good enough connection to the wires.
https://store.ijdmtoy.com/pages/turn-signal-light-50w-6-ohm-led-load-resistor-installation-guide
I'm not ready to shell out $80/side for a hyper flash solution and would rather make my own plug-n-play solution for less. So far I was able to find what kind of connector is needed. Now just need a good load solution.
https://www.bmotorsports.com/shop/product_info.php/products_id/2289
https://www.bmotorsports.com/shop/product_info.php/products_id/3481
