Neither Tunerview, Hondata, or AIM Solo DL offer Oil temperature/Oil Pressure readings. I too am wondering where anyone else has mounted their gauges?Tunerview is cleaner and easier....
Not very pretty is it?Hey guy's,
Wondering who has installed gauges such as water temp, oil, ect... like the photo below and how/where you have mounted.
Thanks
I have seen your post previously, were you able to finally have the gauge installed and mounted? How did you mount/make that bracket?
Oil Temperature & Oil Pressure ( + Real Time Active TPMS) on a 2018 Si.
Note: Required mounting aftermarket Oil Temperature & Pressure sensors.
Switch is to select 2 alternative parameters to be displayed on the Dual Gauge -- (for future expansion)
Still plenty of room to slide in the Smartphone for Android Auto.
Not yet -- still in Prototype "Mock up" stage.I have seen your post previously, were you able to finally have the gauge installed and mounted? How did you mount/make that bracket?
Pick up the thin innovative combo gauge like someone else in this thread did. Probably can mount the sensors to an adapter plate near the oil filter, or at least that is the option I remember from when I looked at it years ago for another car.Neither Tunerview, Hondata, or AIM Solo DL offer Oil temperature/Oil Pressure readings. I too am wondering where anyone else has mounted their gauges?
I agree, I am waiting to receive my USR Side mount oil cooler kit which will come with provisions for a pressure and temperature sensor. I would never put the gauges on top of the dash on this car, just trying to see what other pod options are available or if anyone has tried anything else besides a typical round gauge.Pick up the thin innovative combo gauge like someone else in this thread did. Probably can mount the sensors to an adapter plate near the oil filter, or at least that is the option I remember from when I looked at it years ago for another car.
I am not tracking my car so I never could justify putting in the oil pressure and temp sensors. Even if I was, I would consider adding an oil cooler instead or in addition to the sensors. If you are concerned about the oil temp, probably a good idea to monitor and improve the cooling capacity. No?
This could be helpful.Hey guy's,
Thanks
I see the red blinker for the water temp gauge. did you manage to get it working ? using only the OBDII port?Hey guy's,
Thanks
