18x9.5 +38 On Eibach Prokits Tire Fitment
sheldon
sheldon
Fk8
Looking for clarification on wheel fitment (rubbing/ clearance)
Wheels: Ray Grams 57dr 18x9.5 +38
Lowering springs: Eibach Prokits
- I want to use Michelin PS4S 265/35 tires. Anyone currently or know someone that has this setup on their FK8?
- Do I need camber arms?
All feedback is greatly appreciated!
Thank You
Ouhei
Raleigh, NC
2019 CW CTR
You will probably rub, though fairly lightly from what I've read. Reports are mixed with that offset and a 265/35, but the general consensus is that +38 needs either 255, a narrower 265 (like a firehawk 500), or camber to avoid rubbing without modifying your fenders.
I'll be lowered on Spoons with the same wheels and 265/35 Firehawks on Monday so I'll find out for myself soon enough.
02SilverSiHB
Annapolis, MD
2019 FK8
ah yeah, seems like the general rule is to stick with 45 offset for that tire size. Hopefully you don't rub Ouhei
sheldon
sheldon
sheldon
Fk8
Maybe 255/40 michelin PS4S would fit better?
Ouhei
Raleigh, NC
2019 CW CTR
From what I've seen with the Firehawks is most people either don't rub or have a super light rub on the plastic. Hoping I get lucky. I had a ton of mulch in the hatch area last weekend that dropped the rear down to nearly what it is with the spoon springs and I didn't have any issues so I'm hopeful.
255/40 can be harder to fit than 265/35 because of the extra height, it's a less common size so I haven't seen many examples though.
ctr1750
Pedro
2017 civic type r
Thank You
I’m on eibach sportline which is lower than prokit with 18x9.5 +42 on 265 35 18 falken Azenis no rubbing , you might get a slight rub on +38 but a friend of mine had that offset and 265 tire and he only rubbed on bumps when two adults sat in the back.
Honda Civic 10th gen 18x9.5 +38 On Eibach Prokits Tire Fitment BDED76BC-F022-44FE-A792-B2B0364577E7
Honda Civic 10th gen 18x9.5 +38 On Eibach Prokits Tire Fitment 1781842E-32D5-4943-BCDB-A8A5074959D1
idragmazda
CT
Fk8
Did you need any camber arms on the rear to clear this wheel / tire combo? I am waiting on my +42 CE28N in Bronze from ICB and will be running Sportlines as well. Thanks.
ctr1750
Pedro
2017 civic type r
No they fit without the arms and there was no rubbing
