My KTuner experience - an ongoing journal
OceansX
Brampton
2017 civic hatchback sport touring
Honestly, you really need a custom tune. Also, have you considered an IC?
I have, but the prices here in Canada are ridiculous for everything
theblackdogman
Matt
Orlando
2019 Honda Civic Sport
@gtman I will be ordering my Ktuner in 2 weeks and like the logic from above as it matching my driving style. At what RPM do you get to your boost target on your Tune 2 and 3 settings?
The full 19.5 and 21.5 targets? 3500 rpm.
theblackdogman
Matt
Orlando
Sounds good. I bought a 2019 Civic Sport Hatch and then left the next day for 3 weeks straight. I guess it has to wait until I get home.
theblackdogman
Matt
Orlando
I'm still new to all of this and have another question . in #151 @gtman shares his commuter tune where it reaches 16.5 psi at 2750. Is there any danger in pushing this back even earlier (between 2000-2250). I'm not sure if that is even possible so please ignore if my question is dumb.
Not a dumb question at all. Questions are good. You shouldn't push full psi too low in the rpm range because that's where you can run into transmission issues. And yes, you can manually change the boost targets at any rpm at will. You just have to be careful.
With things like early spool and more aggressive part throttle turbo response, there's no need to chance cranking up too much boost at low rpm.
On the other hand, I sometimes raise the boost targets in the 3500-5500 range.
Andre80
white civic
Europe
Civic X 1.5 sport +
This is my version of 16.5 / 21psi
The car is a monster
Having disabled the rev hang I preferred to soften the Padding throttle the engine was too shaky
I was sure there was still power
Honda Civic 10th gen My KTuner experience - an ongoing journal set
now the 16.5 psi is very enjoyable
In the 21psi I also know a lot of power between 3000/5500 rpm but over sits
Since you have early spool enabled, try going up a bit on the turbo responsiveness setting from factory to improved I or II. It will give you a quicker feel in traffic (less lag).
Andre80
white civic
Europe
Civic X 1.5 sport +
Honda Civic 10th gen My KTuner experience - an ongoing journal teast
forgive me I have the wrong image, I set it up like this
OK, much better. :thumbsup:
Andre80
white civic
Europe
Civic X 1.5 sport +
There is so much more power than Stage 2
I don't believe it yet, that it can have all this power on 1.5, it's really incredible
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
@Andre80 : Could you post AFR.CMD AFR and Actual Ignition numbers on your 16.5psi and the 21psi tunes? By the way I have the exact same boost table in ECO and it is super fun, especially for the hot summer days here in Greece with ambient temperatures of 35C or more :)
Switched my Mishimoto silicone hose / AEM Dryflow filter combo back to my original PRL silicone hose / aFe Pro Dry S filter combo. Power delivery is the same but I have noticed slightly better fuel economy with the PRL / aFe setup.
As far as the tune, all is well. But these humid 90+ degree days really cut into power output.
