Can I change just the exhaust tip for my tire r?
Alim_N
Alim
Guelph, ON
2018 CBP Honda Civic Type R
Wondering what my options are for changing my exhaust tip? Just want it to be two black tips, but don't want to change the rest. Thanks for your time.
Night Fury
Chicago
Black Type R
I think is possible, you just have to look for the welding points & cut from there. Then power coating.
Honda Civic 10th gen Can I change just the exhaust tip for my tire r? Honda-Civic-FK8-2018-Type-R-Exhaust-OEM-_57
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
hikaru
Shawn
Marietta
2018 Civic Sedan 1.5T, 2009 Accord Sedan 2.4 LX-P, 2000 Civic Sedan EK4
Cut the center tip off, then have the rest painted in black.
Done.
It will look like Greddy SP.
Honda Civic 10th gen Can I change just the exhaust tip for my tire r? 1659404142352
xXoVrKiLLXx
SC
2019 Type R ABM
Have a legamax - wanted a free'ish 3 tip option. Thanks for the idea though.
xXoVrKiLLXx
SC
2019 Type R ABM
You can only change the exhaust, but it must be changed within a certain range. The exhaust hole is too large and the pressure inside the car is not enough, which will lead to poor power attenuation. After all, the purpose of changing the car is to change the faster and faster. Gas, just listen to the sound. Modifying the exhaust and the intake at the same time will affect the displacement of the car, although it is the most reasonable modification, but if you don't blow the car, you don't need to change it.
Lol I think you misunderstood brother- I literally just want to change the center tip to be larger or the same diameter as the outer tips. Not the exhaust - as I stated above I have a HKS Legamax installed already and was looking for ideals/pics of other members that have successfully changed the center tip off the stock FK8 exhaust to match to be larger than the 2 outer tips. This was the ony thread that popped up when I searched Google for an answer.
xXoVrKiLLXx
SC
2019 Type R ABM
Old thread - Ill swing by a local exhaust ship and see what they can do for me. Thanks anyway fellas.
