Type r steering wheel removal
CosmicTouring
Bay Area
2016 Honda Civic Touring, 2014 Honda Civic EX-L Navi
Did I miss something? How do you remove the air bag? You just pull it off?
There are 2 bolts, 1 on each side of the steering column, that needs to be removed. There should be a video on YouTube.
Andjoo
Vancouver, BC
2018 Civic Type R - CW #19431
I literally just installed a new steering wheel an hour ago, used this video. Whole install took me maybe 30 minutes
Honda Civic 10th gen Type r steering wheel removal IMG_1871
Mrbadwrench
Minnesota
17 civic ex-t sedan
Did anyone have to get an alignment after getting a new steering wheel? I just installed a buddy club and I have to have the steering wheel turned about maybe 2° to drive straight down the road. If i let go of the wheel then It drives straight. Will an alignment fix this? Because I just got one before I installed the wheel
_1slowsi_
San Fernando Valley
23' Si
following!
Kotaas
Ruben
2019 civic si
I don’t think it’s necessary I haven’t done my alignment I’ve had the new steering wheel for about 3 months no issues. You have to keep the steering wheel completely still and centered the whole time you’re tightening it down so perhaps it slightly moved or you just didn’t put it on completely straight.
Project-09373
Chris B.
Cupertino, California
RD7 | FK8 | YZF-R1
Pull it off and realign the splines– You are probably off a few from dead center. I have dealt with this a million times.
_1slowsi_
San Fernando Valley
23' Si
going to have to redo mine.
Mrbadwrench
Minnesota
17 civic ex-t sedan
It's installed centered. If I move it either directions then it's off by 10-15°
Mrbadwrench
Minnesota
17 civic ex-t sedan
This is how it drives straight now
Honda Civic 10th gen Type r steering wheel removal IMG_20210325_165245379_HDR
versus the very next spline setting would be this far off
Honda Civic 10th gen Type r steering wheel removal IMG_20210325_171449340
Project-09373
Chris B.
RD7 | FK8 | YZF-R1
Hmmm... well to be fair, I've seen some aftermarket steering wheels (buddy club included) completely misaligned.
It could be the splines inside the aftermarket wheel.
Try popping your stock one back on, if it lines up... its the wheel.
Mrbadwrench
Minnesota
17 civic ex-t sedan
So will an alignment fix that?
mecheng32
2018 FK8
You can get an alignment and ask the tech to do a tie rod adjustment. This will straighten the steering wheel. Inform them that the steering whee is off center. Any competent alignment tech should know how to do this adjustment. Done it on all my cars.
