Wet weather advisory
Lilruben1
Ktuned ‘18 Si
Ruben
Fort Worth, Texas
2018 Honda Civic Si
Hey guys, I just had my first experience driving in severe rain lowered on D2 springs as well as with Ktuner. (The tune I’m running has VSA/TC OFF) It was not fun. I was basically sliding all over the place anytime I hit standing water on the freeway. This is just a heads up for you guys to be safe out there on those slick roads. Also, I was thinking @KTuner is there a way to turn VSA ON after flashing a tune with it turned off? If not, would that be a possibility in future software updates? That way if we ever have to drive in inclement weather instead of flashing a whole other tune (which might or might not have it disabled cause tbh I forget what some of them have and I’m sure a lot of us do) in order for us to be able to drive safely?
Like before, be safe guys! Thanks.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
The point of disabling something is to have it disabled. If you want to use it sometimes leave it enabled and disable it when you want with the regular commands.
OP, sounds like you might want to consider setting up the Advanced VSA instead of disabling it.
JR, reading between the lines, I think the guy was asking if you could set up a way of just pressing a single button instead of doing the pedal dance to fully on/off VSA.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
He asked if there's a way to turn it on after you've disabled it in a tune. No, but there's always been a way to disable it when it's enabled in a tune. Stick to that, was my point. :)
