Who has changed their Rear Motor Mount/Pitch Stopper?
Roadcone
Kyle
Upstate, SC
'14 FR-S + '19 CTR
because it's not even worth their time to mold something like that. I wouldn't. You could literally go to the hardware store and buy some window molding for 10-20$ and DIY. If you cry and say it's too harsh, then remove it. The gaps are small AF. I don't even know what the big deal is, but i guess everyone's different and got their own opinion of NVH. Just go buy the HASPORT and be done w/ it.
It's crazy to me, this topic got 18 pages. But, I guess i'm contributing to that :crazy:
all of the poly mount videos are showing what i would consider to be the same as a fully solid mounted setup. That shit doesnt fly on a daily driver and if it does, props to you. i bought the R to be a comfy daily that is fun to drive, i've got a ruined racecar for racecar things...
PowerPerLiter
Specific Output
Midwest
EXACTLY rofl!
SloPoke83
Ben
Jacksonville, FL
2018 Civic Type R
I don't think I missed this question, but will a stiffer mount really be needed with the traction control option now available from Hondata?
Roadcone
Kyle
Upstate, SC
'14 FR-S + '19 CTR
it SHOULDNT be but there's a fair number of us keeping stock tunes that could use the mechanical advantage but would like to not have the dash shake apart.
fmoua916
Nothingbettah2do
Fong
Sacramento, CA
2017 civic type r agean blue
My dash don’t shake apart. If I drive normally I don’t even no is there til I start smashing it then performance is felt!
Chi_The_Process
Minneapolis
2019 Honda Civic Type R
Quick review of @27WON
Overall product:
This mount is significantly beefier than the stock motor mount. The mount has a poly insert on the motor side and a fixed non poly on the chassis side.
Install:
The removal of the stock motor mount was extremely easy. I had watched multiple videos on how to install the aftermarket motor mount. Some things that were missing as a quick tip. After removing the stock mount. The motor drops a few millimeters. This slight drop made it impossible to install the 27 WON mount without a struggle. Key advice, take a low profile jack and jack up the motor just a hair. This would would you line up both end points on the motor mount.
Initial reaction:
The very first start up WOW! The car VNH sounded like I had install 3 inch catless straight on the exhaust. On a scale of 1-10, the cabin noise went from 0 on stock to 10+ with this mount. You can feel the vibration through your seat, steering wheel, and dash. You can also see the hood vibrate at a stop! The initial drive, anything over 5k sounded like was shooting a Desert Eagle. The buzzing and drone effect was almost unbearable. I did a hard pull of the line and the wheel hop was definitely smoother/non-existent. The second gear pull was way smoother than stock.
I only have 50 miles on it right now and it definitely improved over the initial VNH!
Honda Civic 10th gen Who has changed their Rear Motor Mount/Pitch Stopper? 6C0EF07C-0BD7-4664-9292-FF5B46CA0734
Honda Civic 10th gen Who has changed their Rear Motor Mount/Pitch Stopper? 8BE75B31-A0FF-438B-B7BB-85D86FB99976
akadic
Jacksonville, FL
(sold) CTR 1722
After a couple thousand miles I felt my full throttle first to second shifts were somewhat too aggressive (could be feel only). I lifted the car up to check if perhaps my pitching stopper bolts were loose. They were not but I was wondering if this wear and tear is normal or a quality issue?
Honda Civic 10th gen Who has changed their Rear Motor Mount/Pitch Stopper? cusco
.grimace
Byron
Reno, NV
That’s the second Cusco one I’ve seen falling apart.
.grimace
Byron
Reno, NV
Same here, I need to lift up my car and see if my 27WON rmm is holding up after 5000+ miles.
x2, I’ve had my Hasport for close to 10,000 but not even worried with a company like Hasport.
Type-JZ
'13 Lexus GS350, B13 Sentra SE-R, '93 Camry, '07 TSX, '13 Odyssey
I’ve seen someone’s 27won bushings rip. I have hasport. I chose them simply because they’ve been making mounts for over 20 years probably. Not saying everyone’s perfect though.
redline
Olathe, KS
My cusco mount is doing the same shit, for dam near $300 dollars for a mount you would think it would hold up a little better lol. I'm going to get a replacement and sell it and switch to the 27won.
akadic
Jacksonville, FL
(sold) CTR 1722
I paid $175 shipped from Rakuten :). They responded to me as well, sounds like I am getting a replacement. I also ordered the hasport one and will put that one on next to see the difference.
