2017 Civic turbo engine rattling
dc2turbo
usa
civic,teg
OP- Post a video with sound off to the side and hood down? If this were an older car, it sounds like some additive with lube for lifters might be worth it. Was the car warmed up when this video was taken? Compared to my vehicle, the sound on yours is rather loud.
the ticking sound is the direct injection. of course a video record could be louder since it's using a mic to pick up the sound
GaryXgen19
Gary
Massachusetts
2019 Honda Civic si
Sorry to bring up an old thread but been looking to see if anyone’s has this Extra noise either I’ve had and not realized or just started. Besides the direct injection ticking. I’m also now hearing almost like loose change noise. Anyone know what that could be. Like light tinny noise like really almost coins swirling in your hand? Replies would be appreciated!!
LightX
Andrew
2018 Civic Hatchback Sport
Mind started to sound like direction injection but louder and goes with the pseed of the engine. Took it to honda and they diagnosed that it's the pulley and belt. The timing was off apparently.
RetroJR
US
2017 EX-T 6MT ViTuned
The pulley belt would have had nothing to do with timing though. Did the dealer tell you that? Our engines have timing chains.
LightX
Andrew
They've replaced the timing chain and pulleys, didn't do anything. My guess at the moment would be the valve clearance, or something with the cams. Will have to go to a shop to get my valve adjusted see if that does anything. The sound started right after I did a pretty hard first gear pull to redline, probably messed up the valve nuts or whatever lol.
