Lower stock shift knob by making more threads?
boyguan
Bay area
Type R
i changed the knob today and noticed it had plenty room to chase the threads to get it to sit lower. I remember I cut my shifter on the s2000 and got it to sit lower after I made more threads.
Anyone try this?
jasonjm
Jason
Pennsylvania
Type-R
baldheadracing
Craig
Canada's capital
FK8
I tried to thread the stalk tonight. My M10 1.5 die didnā€™t seem want to start on the stalk. Wasnā€™t trying to break anything but need to know what was used.
I tried a 'normal' die and had the same experience. The link that you quoted has links to the thread-restoring
dies that I used.
elmerzasty
Poland
FK8
Its very, very simple, just be careful to go forward and back every turn to allow debris to escape (there will be lots of metal bits so place some towels around the area to catch them).
Even the stock knob has plenty of hollow space inside to get it lower than stock.
In my opinion (as most shift mods are very subjective) I would recommend this mod as it forces the use of a bit more force when shifting, as a result the driver is in control of the shifting motion as opposed to stock height where the shifts sort of fall into place like a pendulum. Shorter shifts and gate spacing are an added benefit.
Honda Civic 10th gen Lower stock shift knob by making more threads? 11116CCA-11B7-4196-B86A-A8D096016A46
Swmmo
Scott
Atlanta
2021 civic hatchback sonic pearl gray
Hey Iā€™m way late to the party I know, but just had this idea and was hoping for some input. Iā€™ve got the stock shifter that I want to die cut to get my skunk2 knob lower.
The question: Is there excessive rotational stress on the shifter if you die cut it in the car? (Normally Iā€™d clamp the bolt in a vice to keep it from spinning).
My concern is damaging any other shifter internals by putting too much rotational force while die cutting it. (Does my question even make sense?)
thanks for any insight you might have to offer.
