dx91
- C
- Nov 23, 2018
- 2
- 8
- 0
- Canada
- 17 Sport Hatch
I’m trying your tune right now (starter stage 1). However my knock control (I think) is around .49 when cruising city streets from 0km/h to 80km/h.Stage 1 is fine but you can use the starter tunes and have the same 18 psi, then bump up some of the driveability settings. They will put you beyond the Stage 1 feel if you want.
For example, you could try this setup:
Enable "early spool" in the quick enables. For quick adjustments, set your throttle response to Improved II, turbo spool at Improved II, turbo responsiveness to Improved II or III and boost ramp at Aggressive I or II. Upload your new tune and enjoy.
If for some reason, you still prefer the basic Stage 1, simply re-upload that. It's all about trial and error with tuning. Just remember that all the quick adjustments are safe. The only one I don't recommend is disabling boost ramp. It's too harsh.
On the highway when I pull harder around 3-4K rpm to reach 100km/h to 120km/h my knock control goes from .49~.59 to .69-.79.
When I start cruising (not pushing the throttle too high) my numbers are at around .8 but never goes over .9. When I push the throttle to about 3-4k it’ll sometimes bring me down, while cruising it’ll give me some higher numbers and stay there until I put the throttle down.
With eco mode on, I’m getting 0.49~.59 on highway, and city driving. With the occasional .6ish. I’m using 91 Octane, from Shell gas station and Petro Canada gas station.
Should I reduce my boost ramp to aggressive I instead of II? Or is there something I did wrong with the tune?
Thanks!
