***MAPerformance Civic SI 1.5t Catback Release and Group Buy!***
Status
Not open for further replies.
MAPerformance
MAPerformance
Cottage Grove, Minnesota
www.maperformance.com
2017 SI Coupe
This is the result of messing with it forever. Initially, it hung super low too.
ive heard this a few times but our exhaust hangs as low if not higher that the stock exhaust
AREA
Houston, TX
18 Civic SI coupe
Yes its all based on adjustment. If you keep everything loose enough to be manipulated it can tuck extremely tight. So tight it could rattle against the chassis. People are not properly adjusting the piping to tuck correctly. A lot has to do with the resonator piping the angle you place that at will determine how tight the exhaust fits. If you have that pipe tightened down at the wrong angle it will throw everything off. People need to leave that front v-band loose. I have installed multiple MAP exhausts on the new SI models and that is what I have found.
Wingman520
Brian
Canton, Ohio
2020 Honda Civic EX Hatchback
I would love to get this exhaust, but no center exit on my civic exhaust. Maybe make an option for y pipe dual exit with turn downs a possibility? I know it sounds far-fetched since the center exhaust exit is the most popular on this generation civic and the type of exhaust I have on mine isn't as comming. Thought I'd at least share my feedback.
dodgeswinger73
NW Georgia
2018 Honda Civic Si
I really wish this exhaust system just used 3 bolt flanges. That would take all of the guess work out of it. I particularly hate the slip joint clamp on this system. I just want to be able to hang it, bolt it together and have a factory like appearance and fit.
givemeadollar
Matt
Multiverse
2018 Civic Si Coupe
Slip joint clamp was a lazy and quite stupid choice, not going to lie. I tightened mine then tack welded it so hopefully that piece of crap will stay put.
N0TYPR
Abban
Baltimore
Civic Si
Question for all the members that currently have Map exhaust.
I am in the market for a rear diffuser. Does anyone have one yet?
Bmspec, Aeroflow all said our exhaust is to wide. Hopefully someone else has had better luck then me!
Honda Civic 10th gen ***MAPerformance Civic SI 1.5t Catback Release and Group Buy!*** 56757211_2624046817637927_1107260891239284736_n
MAPerformance
MAPerformance
2017 SI Coupe
This is solid feedback. It's a super good perspective to have... we HAD to use slip clamps on some of our systems with dual exits where customers needed a bit of wiggle room to get their systems completely lined up to their satisfaction. I will farm this back to the team. Thanks for the heads up
CivicSiNJ
Hampsen
New Jersey
2018 Civic Si
Where did you get that duck bill ?
CivicSiNJ
Hampsen
New Jersey
2018 Civic Si
Hey MAPerfance could i get a link to the coupe civic si maperfance race exhaust because i can’t seem to find it ?
MAPerformance
MAPerformance
2017 SI Coupe
CivicSiNJ
Hampsen
New Jersey
2018 Civic Si
Status
