RAYS CTR FK8 Spec Wheel Options
realcop0794
ZURKON
Corey
Elkhart, IN
2018 Honda Civic Ex Hatchback, 2018 Toyota RAV4 XLE
:dunno:
Hey straight noob here when it comes to buying wheels. I've got "oem" procontact tx continental 17" tires and I'm looking to put ENKEI Kojin17X8 5x114.3 wheels with an Offset of 40 on my '18 hatchback ex. Can anyone PM me anything I should know or let me know if this is compatible?
DatSauce
Tampa, FL
2001 Integra GSR, 2011 Honda Fit, Rav 4
:dunno:
Won’t be compatible, the 17’s won’t clear the Brembos and Type R is 5x120.
realcop0794
ZURKON
Corey
Elkhart, IN
I would've just made a new thread if I knew how, but I don't have a type R regrettably as I stated. I have the EX hatch.
mnksauce
Bay Area
2018 Civic Type R, 2005 RSX Type S
Put on some TE37SL
18 x 9.5 +38
Firestone Firehawk 500 265/35/18
Stock height (for now)
I opted to get hub centric rings. Quick warning if you're looking at Mackin ones. Make sure you get the correct ones.
I had to get another set specifically for our sizing after a bit of headache and getting the rings out of the rim. The rims are much harder a material than the rings...so good to know.
Wrong Set
73.1mm -> 64.1mm
Honda Civic 10th gen RAYS CTR FK8 Spec Wheel Options MVIMG_20190305_205100
Right Set
72.6mm -> 64.1mm
Honda Civic 10th gen RAYS CTR FK8 Spec Wheel Options IMG_20190318_104618
antyee
Bay Area
'19 CW Type R, '06 Accord EX
Anyone rubbing issues with ze40 18x9.5 +40 offset on 255/40 tires on stock height?
KeepItLow
Sydney, Australia
Car
TE37 Saga Time Attack 18x9.5 +44, set on putting 265/35 tyres but seeing some doing 255/40 as well. Any pros and cons for this? Thanks
CincyTypeR
The 255/40 is closer to the stock diameter so the speedometer will be more accurate. That is the size I went with this time around. Although I did long contemplated the 265/35 since that would have had more grip since it is slightly wider.
KeepItLow
Sydney, Australia
Car
I'm looking at tirerack and looking at tyres diameter and rolling, 255/40R18 is definitely closer to stock 245/30R20 we have. Would you happen to have a photo of 255/40 on 18x9.5 rims, I'm looking through every page to find some examples. Thank you! :)
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
255/40 has closer rolling diameter than a 265/35 so your speedometer would be more accurate. Not like the 265/35 is a big difference though.
I have 265/35 on my sagas because I wanted a wider tire.
KeepItLow
Sydney, Australia
Car
Thanks for this.. I'm searching through the thread for some photo on 255/40 on 18x9.5 +44, would like to see how it looks :)
CincyTypeR
Stock ride height
255/40R18 Michelin P4S
Honda Civic 10th gen RAYS CTR FK8 Spec Wheel Options 255 40 Tire
