Florence_NC
- Sep 25, 2018
- 2
- 340
- 220
- North Carolina
- 2018 Type R
I got my 100% stock CTR up on the lift earlier this week. I didn't have the light to get good pictures but I did get very good measurements.Florence, agreed, that looks like a good deal of clearance. Shocking actually, with a 10" wide wheel at +55 offset. Several other companies, Apex, included have recommended far less offset because of fear of clearance with the suspension.
Please keep us posted when you get measurements!
REAR: There is about 1" of clearance between the tire and the strut. The closest clearance spot is actually between the tire and the trailing arm, but it still has about 7/8".
FRONT: The design is way different than a typical strut car, and has much more clearance. Closest spot is between the tire and strut where I could just get a 3/4" (19mm) bar to pass between the tire and the strut. At full lock in both directions there is tons of clearance everywhere including brake lines, steering rods, frame, inner fenders, etc. The strut is the only real limiting factor inwards.
So to break this down, if you were to put a 10.0" wheel with +60 offset, that would add 3/4" to both the inside and outside of the wheel. With 3/4" clearance on the OEM setup, that would put the tire just touching the strut, so clearly some additional offset is going to be needed. But a bunch more offset (like 25mm more that ET+35 would give) is not needed. Moving to +55mm is moving the wheel outward 5mm (.200") which would be enough clearance for most wheel/tire combos, and is still farther from the fender than a 9.5" ET+45 wheel. Yes, that is correct, this gives a wider wheel with more fender clearance. So it does indeed look like to me that the 19x10.0" ET+55 wheel WILL fit on the front and the rear, with some attention paid to the actual tire profile to see how close it is.
If you have a 9.5" wheel, that would leave about .250" at ET+60. Zero reason for any offset change on a wheel 9.5" or narrower. So there is no reason why these wheel companies should be trying to push these +35 to +45 wheels on us. It doesn't make sense. Why only add extra wheel width to the outside, when you can add it in both directions to get even more width AND keep the geometry where Honda designed it?
Tick. Tock. Tick. Tock. Tick. Tock.
This is me turning blue as I hold my breathe waiting for a wheel/aftermarket company to explain to us why they are pushing improper wheel choices on us.
