yes you can however you have to be considered that your rear camber angle will increase from 1,25 degrees to abt 2 degrees.you can see mine fyr. https://www.civicx.com/garage/boe921.1873/
Thank you guys! have you encountered any problems with the springs?Yes, no problem. I did it on my Sport+. Eibach pro.
I have no problem with springs and really like ground clearance which is provided by pro kit. you will not lose any comfort up to 100-120 km/h almost same as factory setting however after that the car will jump very lightly depending on road surface.Thank you guys! have you encountered any problems with the springs?
pro kit eibach (winter tires 16") ride is great much better than factory car is stiffer for sure, but stil not to stiffHi guys, i'd like to drop a little bit my hatch, as you may know here in Europe the sport hatch has the electronic adaptive suspension, do you know if it's possible to replace the stock springs in these suspensions?
I don't know. It's strange but on some cars they seem to lower enough for my taste but on others they don't look low enough and they're all Sports/Tourings with Eibach Pro.So it seems like eibach is the go to for most people
Anthony car looks amazing!!. what all is needed for the spoon sports lowering springs? camber kit? also what is your wheel/tire size and set upI'm on Spoon Sports progressive springs
Ride quality is not comprised. Body roll is greatly reduced and the car feels more Sporty to drive
