commando81
- Jul 2, 2018
- 1
- 8
- 2
- Cuse NY
- 2018 Civic SI coupe
You need rear brakes already? That doesn't sound right. If the car has been sitting I can understand some flash rusting on the rotors that would cause some noise during the first few stops but if you are under a year and less than 20,000 km and you've performed the recommended services (i.e. brake servicing) you could be covered under warranty but I would speak with your service advisor for the final word.
As for the rear suspension sound, give Honda some time to figure it out. It's obviously a Si specific issue and Honda as with any manufacturer relies on the number of customer complaints to determine whether to develop a TSB or update so make sure that you bring the car in and have it looked at even if there isn't a fix or the parts that were supplied don't fix it. Remember the dealer can only fix the car with parts that are available from the manufacturer.
The brakes are a common problem too. I’ve put a ton of miles on, but it’s 90% highway so not much braking. Involved. Dealer told me it’s a wear item
