ThrillHill
- Mar 8, 2016
- 8
- 108
- 56
- New England
- 2016 Honda Civic EX-T
Hi, can you help me please :I work for Honda in the parts division....A01 or A02 will fit all Honda
15400-PLM-A02 (That's the one we use) made by Honeywell ...
15400-PLM-A01 is made by Filtech
You can have a 92 Civic or a 2017 Pilot ...IT'S THE SAME FILTER!!
The only difference between A & B is whether or not the oil filter is to be changed. So when you replace the filter and clear the B code, the next one is going to be an A (oil change without filter). The 1 indicates time to rotate the tires as well.Hi, can you help me please :
I used Mobil 1 M1-110 oil filter + 0w-20 Mobil oil + Honda 94109-14000 gasket, but the 1st time i changed, It got code A1, and the 2nd time is B code. I followed the steps to clear code in manual book but it did not work. I did it very carefully. Last time, I brang my girl to dealer, but still got A1 code.
Sorry my bad English.
Just checking (nerd alert here) - S2000 uses a different filter correct?I work for Honda in the parts division....A01 or A02 will fit all Honda
Yep I can confirm that.Just checking (nerd alert here) - S2000 uses a different filter correct?
Also, the Fram filter number used to be 3593 or 3693 as I recall - it was a bit fatter of a filter. Going back about 15 years on that number...
