- JW
- Jul 8, 2017
- 1
- 202
- 98
- Somewhere
- 00 Orion Nebula
- Banned
- #31
The Type R does not require any special firmware update, as it's the exact same firmware used on 2016+ Civics (i.e for Blade AL it would be HA6)So update for remote start is out?
What's different in the Type R is the CPSS [Clutch Pedal Stroke Sensor (VSA Modulator Control Unit)] #3 pin (YEL: CSS_SIG2) must be broken during crank with a relay, in addition to the CPPS [Clutch Pedal Position Sensor] #4 pin (YEL - located at BCM Connector C #26).
- The CPSS is impossible to get to without clutch pedal disassembly, therefore this wire must be found in the main harness that exits through the firewall on the driver's side. There are ~5 YEL wires in this bundle, with the correct one reading ~3.5v when off and ~1.3v with clutch depressed.
EDIT
- Updated attachment, as Blade schematic was missing a tracer line for PTS (+)
- The CPSS relay must be triggered by a second negative start output
- If using CompuStar, I've utilized POC #4 (CN5 #7), configured in Option Programming as #2 (second start out)
Please utilize my GitHub link for the most up to date version of the attached PDF, as the attached version is no longer current
