Safety Recall: Replace AC unit update PCM
OverX
2018 Honda Civic Si Sedan
What's your idle rpm now compared to before? I have a CVT not sure if same as manual but it would idle at 600 with no electronics on (headlight/fans) and 700 with anything on.
Seems like it would use more gas if idle is up..
I will have to check what its like while warm but when its cold it went from 1500rpm to 2000rpm
BoxsterSteve
still plays with cars...
Baden, ON
2000 Porsche Boxster S, 2018 Civic Touring sedan
Had my car done today after work. Under 90 minutes...
Software update, control unit swapped out & oil changed.
Pulled in at 3:40, out before 5:00.
Have to see if it behaves/feels any different in the morning.
civicdota
Toronto, ON
2017 EX-T Sedan
Please report back on idle RPM's on startup and when warmed up. I'm curious :).
BoxsterSteve
Baden, ON
It buzzed up to 2k for a second or so, then settled back down, but it was -4C this morning when I left for work. After sitting all day it went up to 1800 and back down again almost immediately. Outside temperature was 4C at the time.
Warm idle is unchanged.
Whatever this software update does is, it’s kinda invisible.
M.R.C.I.V.I.C
2017 Civic EX-T
I have to agree with you. The RPM after the car is warm is the same as before the update. It was -10 this morning here and the Car does now warm up faster. I don't remember seeing the rpm going to 2000 this morning though. Ill have to check t0morrow.
civicdota
Toronto, ON
2017 EX-T Sedan
Any updates on the mileage now that some of you have had this done for a few weeks now. Has it gotten worse?
elmer255
NY
2018 Civic Hatchback Sport CVT
I had mine done today- funny they said Honda would cover the plug washer and 4 quarts of synthetic oil but not the additional quart and the filter. Only thing I noticed different about the car is that they said on the ticket that they adjusted the tire pressures to factory specs- which apparently are 150PSI :)
SCOPESYS
Geoff
MD
Doesn't that give you a nice "warm and Fuzzy feeling" when you take your car to the dealer, and see that !!!
The whole thing with charging you for the Oil Filter, and for the extra 20% oil required to fill to OVER the dip stick marker, is just plainly stupid. All it does is PISS OFF the Customer, and makes them despise the Dealer even more for being so petty.
BTW: Did you get one of those "Check" reports.. where they check off about 30 items, on a pretty red and green form. I bet that made you feel good as well !! :rofl:
elmer255
NY
Oh yes, got the report with all of the check marks too!!!
SCOPESYS
Geoff
MD
And each TICK was Identical ? ie All ticked off at the same time. !!
While it could be that the checks were transferred from another Shop Form, it would look a lot better if they took the time to be a little creative, and make the ticks slightly different, so it looked as if the checks were actually done, rather than the form just FAKED !!
I expressly told them NOT to touch the Tires or Tire pressures, and not to test them, not to touch them in any way (Including wheel nuts), and that was on the Order the "Customer Service Agent" created when I 1st spoke to him.
But when I got the car back, the Tire Pressure box was checked off as GREEN (ok OK), and I know that they could not have checked them, as I purposely had them over-inflated to 37 PSI, just to catch them !!!
elmer255
NY
Something about those dealer guys where they just have to ridiculously overinflate the tires !!! Drives nuts !!
dallasjhawk
Royse City, TX
they really put 5 qts of oil in your engine?
