What did you do to your Type R today?
spyder57
LA
ABP CTR
JDM Fog Lights finally got delivered! Took about 10 minutes to install...They look great and even better at night ;)
That looks great! Which JDM fogs did you get - could you share a link?
ctrmofo
planet earth
'13 lambo lp550-2, '18 honda ctr cw (r-12321), 14' porsche cayman s, '16 porsche macan s, '13 mini jcw nme stage 1, '15 audi s3 apr stage 2, '15 audi q3, '12 monster 1100 evo, '16 triumph thruxton r, deposited for '19 lambo huracan performante
badass project kics r40 m14x1.5 rotating base lug nuts from @VividRacing
Rayarquillano
Ray
Winnipeg, Manitoba, Canada
2018 Honda Civic Ex-T & 2013 Nissan Juke Nismo
Here's the details from my invoice. I think they were the "small" version. I got them through Kami Speed:
MUG.08P48-XG8-K0S0-S Mugen Power Door Handle Protectors (Pair) | 2017+ Honda Civic Type R (08P48-XG8-K0S0-S) Qty: 2
I hope that helps!
Edit: product link: https://www.kamispeed.com/Mugen-Door-Handle-Protectors-17-Civic-Type-R-p/mug.08p48-xg8-k0s0-s.htm
I’m going to assume that there are difference in handle size between any of the trims. Thanks for help brother!
ctrmofo
planet earth
Don't break your shift boot trim plate tabs by just replacing the boot only. Get this excellent quality Overland Designs alcantara shift boot kit complete with OEM trim panel and swap shift boots in 15 mins or so.
Red alcantara with black stitching reviewed here (and previously reviewed black alcantara with red stitching also linked).
ctrmofo
planet earth
I assume these would work for the stock wheels right?
No, stock wheels use ball seat lugs while aftermarket wheels use conical (like those are).
what he said. you need the ball-conical adapters i've shown for $1 each to use conical nuts. i have them on my nsx wheels: ball-conical adapters and conical nuts. opens up all the aftermarket options to oem honda/acura wheels which are all ball seats.
adapters are from motorsports hardware. shown here how they work.
CWTypeR
Georgia
2018 CW Civic Type R # 20866 and a 2009 Acura TSX for the daily grind....
spyder57
LA
ABP CTR
Thanks! These are the Honda OEM JDM Fogs.....I ordered them from Rakuten....There is a post on here as well with all the detail - so props to the OP that started the thread! Here are the links I used to order -
Fog Lights
https://item.rakuten.co.jp/suzukimotors/trci015/
Adapter (you have to have this as well.....no getting around it)
https://item.rakuten.co.jp/suzukimotors/trci015-1/
Thanks for the links! Man I had no idea that it'd be $400+ to get some JDM yellow fogs...
ctrmofo
planet earth
10 years car challenge...
