BC Coilovers
fdb_fk7
2018 Civic Hatch Sport
my damper settings front and back are at the softest. I called bc and ordered custom rear shock cartridges, they go about 2 inches lower than the max low kit, also swapped out the 170mm max low rear springs for 145mm, I can take a picture of it if that would help you
Were you able to remove the fender gap with the 170mm ?
Dying2Live
Lakewood Ca
2018 LX Sedan Manual
yes top of tire slightly tucking with 170, with 145 top of rim almost tucks and tire fully tucks
Dying2Live
Lakewood Ca
No rubbing up front on bumps? What size wheels and tires are you running?
i was running rpf1 in 18x9.5 +38 and rubbed alot in the front with a 235/40 ohtsu fp7000 tire, switched over to 18x9.5 +45 rpf1 with a 235/40 firestone indy hawks and no rubbing at all even at the coilovers maxed out lowest
fdb_fk7
What spring rates are you running now ?
How's the ride quality at the softest setting ?
Dying2Live
Lakewood Ca
socal818
Jesse
2022 civic sport
My front tire I’m running 18x8.5 +35 with the stock 235/40 conti’s and 8k spring and from all the way stiff to all the way soft I’m rubbing on bumps. I’m just gonna have to raise it up a little I guess...
