SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
OMG: Did not realize just how DUSTY the console is, until I took this photo.. DUST MAGNET.
Yes, I will clean it up -- how embarrassing
Anyway :-
Just mounted my Direct TPMS in the Si.
Located just below the Passenger Airbag warning.
From the drivers Perspective, you do not see the Velcro, but you do see the full parts of the Top part of the display, and it looks like it is flush with the outer edge of the Passenger Airbag plastic.
Attached with Velcro, and Lithium Battery Powered, charged via USB cable, with USB charger in +12v Aux socket.
Being mounted with 10 Lb Velcro, it's not going anywhere, but can be easily removed or re positioned if needed
Reading are the same to within 1 psi of the pressures I measured with another High End Digital Pressure gauge earlier today.
It's Cold ( 35 F). When we last put Nitrogen in the tires, (FREE at Cosco), it was in the 60's, and we had just driven there, so the tires were hotter.
At the time, they put in Nitrogen to 35 psi all round ( according to their meter) with the intention that I would bleed off and adjust when tires had cooled down. (We should have gone higher as they were hot !!)
Once things settle down, and I have done a few trips, I'll decide if I need to change the pressures.
https://www.ebay.com/itm/Car-Tire-P...ternal-Sensors-Bar-PSI-Unit-C1E3/132367486699
$30 on Ebay (including shipping -- Sweet deal)
Yes, I now the Front & back pressures are relatively incorrect, higher pressure should be on the FRONT tires.
The TPMS is set up correctly, thus showing that in fact, the front tires are low !!
The INDIRECT TPMS is not going to pick up on that.
Will be interesting to see how these pressure increase after 30 minutes of driving,,,
The tires are certainly not going to stay at 35 Deg F so pressures will rise.
Very happy with the end result,Functionally, Cosmetically and Cost.
Bluetooth Oil Temperature & Pressure next !!!
(This is going to be a little more difficult !)
