Touring model headlight modification
Brisco
Brisco
Matt
Kitchener
2018 Aegean Blue Civic Touring
I finally can confirm that this kit ads less than 1 amp to the headlight circuit. I’ll be adding it to the DRL circuit within the headlight itself. No drilling or external harness needed to power it. It last retained your OEM function for the blinker flashes when lock or unlock are pressed.
The DRL power wire doesn’t have to have power on it to make the blinkers work. This was one of my recent concerns. There are Red, yellow and black wires on the controller. The DRL is one as soon as red and black get power. Because red isn’t powered when the car is off I had thought the blinker function wouldn’t work. I can confirm it does. There is literally no literature for this kit other than how to wire it up. No power requirements listed. Will keep updating once I find the time to start.
Brisco
Brisco
Matt
Kitchener
Well. It’s been a hot minute but I finally was able to make some progress on the switchback sequential DRL turn signal upgrade.
Once I had the parts I could start to template the mounting out. I ended up using the signal board and positioning the led above the original centering it and then transfering the holes on the Profile boards to it.
I drilled them with a 1.6mm drill bit. It appeared to be the same size as the holes. I ordered 1.6mm x 5mm stainless bolts and nuts for mounting the boards. It worked out pretty well.
I’m going to put a dab of apoxy on the nuts to ensure they don’t come loose overtime.
Honda Civic 10th gen Touring model headlight modification 73E6FE15-4B44-4F13-BB5E-B39F2027BD6C
Honda Civic 10th gen Touring model headlight modification 146A583F-3E37-4DCF-AF57-D4ABEA033C4E
Honda Civic 10th gen Touring model headlight modification EEEFE26A-E7C8-46DB-B384-0C06CD48C42B
Honda Civic 10th gen Touring model headlight modification 633856EF-00AB-45E6-A989-817B52389891
Honda Civic 10th gen Touring model headlight modification 2B58C71A-BEED-4D3D-9EA6-EE0270FF9CB0
Honda Civic 10th gen Touring model headlight modification 349B8D99-3310-41B4-B141-C2EB7CF866AF
yamin1021
cn
2016 civic ex
Any update ? Are these profile strip bright enough under direct sunlight ? Both white and amber mode.
Brisco
Brisco
Matt
Kitchener
I’m getting there. I haven’t had time yet to finish up it’s been busy.
yamin1021
cn
2016 civic ex
i've got these aftermarket DRL board, they do switchback and sequential, but they are very dim under direct sunlight which defeat the purpose of DRL. I might change out all the leds using Pixel one. Only question I have is how bright are
PROFILE PIVOT ? Are they visible under sunlight ? Especially amber mode.
Honda Civic 10th gen Touring model headlight modification IMG_20190121_125231
Brisco
Brisco
Matt
Kitchener
I can’t tell you yet. I have to put mine together. They look bright.
Brisco
Brisco
Matt
Kitchener
Ok. Finally done. I just have to bake them closed again and we’re good. I just can’t decide what look looks better. Original DRL on bright all the time or On low all the time. I’m leaning towards bright anyways.
I have a few comparison shots. It’s really hard to tell when not in the car.
Photos comparisons are ordered bright-dim-dim-bright-bright-dim-stock.
Honda Civic 10th gen Touring model headlight modification A8E779A5-D445-4305-BBE6-0D37F34F8671
Honda Civic 10th gen Touring model headlight modification 6D5F8235-AF53-404A-8D0E-5E35A19A37BA
Honda Civic 10th gen Touring model headlight modification E8BC9228-FFFB-4829-90A4-BABF3B9043FD
Honda Civic 10th gen Touring model headlight modification 87A8BBAE-EFF8-4827-B3CF-A284EB790E2F
Honda Civic 10th gen Touring model headlight modification C71760EE-0AF9-4B60-A46F-161F73841607
Honda Civic 10th gen Touring model headlight modification C4F21302-6861-46B2-BE0E-99F524171B2A
Honda Civic 10th gen Touring model headlight modification B9F69252-4D52-40F3-8DCF-D6ECF8E2B5EC
yamin1021
cn
2016 civic ex
Stock DRLs are pretty blinding at full brightness @ night. That's why they dim when low beam's on.
Brisco
Brisco
Matt
Kitchener
Understandably but so are the headlights. I’m not sure if it will even be noticeable at night with the headlights on.
yamin1021
cn
2016 civic ex
Yes it will . Headlights have cutoff shield so the light will not hit people's eye all the time.
Acey
Calgary
'18 Coupe Si HFP
Not really, which is why the Tourings are rated poor for excessive glare. They're reflectors and have no cutoff.
Brisco
Brisco
Matt
Kitchener
I just listed the donor set for an April to mid April sale. As soon as I can get them swapped in I’ll be selling them. I’d like to get $425 USD + shipping.
Deezy
Daniel
Covington, Ga
2018 Civic LX Sedan 6MT (FC2)
