UK Euro Spec Civic Sport Trunk / Boot Floor - Interchangeable?
futureal33
UK
Civic 1.5T Sport Plus
Afternoon all,
I have a UK Spec Civic Sport Plus (similar to your Si, I think) hatchback.
I'm having some issues with my boot, or trunk as you call it - trying to configure it to suit my needs.
I dont have the spare wheel
I do have the central exhaust pipes
On mine, when I lift the boot floor carpet, underneath it is just bare metal - where the spare wheel would go if fitted.. There WAS a black foam / polystyrene insert here, with the locking wheel nut, wheel wrech and air compressor inside pre-made cut outs.. but I have removed this, as I want to use the area for storage.
I have carpeted over the bare metal, and keep a few small things in there (1ltr oil, water, torch, etc etc) which I like to keep in the car, but dont want them banging around in the boot all the time.
Anyway... the problem with this, is that the old boot floor used to "sit" on the foam / polystyrene insert - which gave it strength. Now I have removed this, the boot floor is hovering over a hollow compartment and its really flimsy - and just bends under any weight at all.
On the Civic models without the central exhaust pipes, the boot floor is totally different - made from something much stronger
The shape looks the same.. although I cant really do a test fit... from visually looking at them side by side... they "look" the same fitment.
Just wondering if anyone knows if the boot floor can be swapped between models... as the "non-sport" boot floor is much stronger, and would be a solution to this problem... allowing the under-boot area to be used for storage, and giving the floor enough strength to put stuff on.. without having the foam insert underneath for structural rigidity
Thank you!
The picture below shows what my boot did look like, but now the foam insert is removed.. that space is just hollow and the boot floor doesn't "sit" on it like it used to... so now the floor is really flimsy and bends in the middle over the hollow space
Honda Civic 10th gen UK Euro Spec Civic Sport Trunk / Boot Floor - Interchangeable? Boot
stephenmeadows
StephenMeadows
Stephen
United Kingdom
Honda Civic Sport 1.5T 2018 Hatchback (European Spec)
The boot floor carpet from a non-Sport model will fit. This is fine as long as you buy/use the non-Sport one without a subwoofer.
I have a 2018 Sport 1.5T Hatchback here in the UK. I also sell Honda parts and accessories, both UK parts and JDM (Japanese) and USDM (USA) spec parts.
I am also an authorised dealer for Acuity Instruments. Check them out!
Stephen
garyd1992
G
Charlotte
2021 Honda Civic Hatchback Sport Touring
Stephen
Hey, I have a 2021 Sport Touring Hatchback US model, if I take out the spare and buy the non sport trim trunk floor assembly, will it fit? I hate the US flimsy sport trunk floor, LOL. Thanks.
