Spoon Springs Install DIY
Jp-R02328
Pablo
Murrieta
17 type r 2009 Tsx 6speed 2003 accord
Question. So I’m currently working on the fronts. I’m following this DIY. But for the mother of God. I can’t remove the last bolt for the lower control arm. The sway bar is in the way. How’d you all do it?!
Did you figure it out? I’m also stuck on this part. Do we have to remove both link on the sway bar before removing the nut? Or can we do one at a time?
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
I just did it using this method and I had no issues.
I just used a jack on the sway bar on the other side to move it.
Weekend_CTR
Erik
So Cal
2018 CTR CW, 2017 CR2 WOP, 2013 GE8 Sport AS, 2011 FA1 PMM, 2016 CR2 KC, 2018 FC1 PMM
Honda Civic 10th gen Spoon Springs Install DIY 92F2D3F1-891F-4C5F-BEDE-C91F9D1DE766
Used this method and it was a breeze. Very similar to the 9th Gen Accord Method. Took a total of about 2hours taking my time. A few tips not noted. I found it easier to loosen everything and remove the lower bolts before removing the strut from the tower. Once the lower arm is loose and the knuckle is free from the strut it’s a breeze. Also to remove the lateral arm you need to jack up the lower arm to get the arm off the mount.
maaaaark
mark
australia
2018 FK8 type R
Did u cut all bumpstops?
Weekend_CTR
Erik
So Cal
I actually installed Swift springs using this method. And I was advised thru Evasive not to cut bumps. Maybe cause of the higher spring rates.
RStoR
NC
'07 SI Sedan & '18 RR #18407
Hoping someone can provide me some help. Using this method to remove my shock. I can't figure out how to remove the LCA bolt below as the swaybar prevents removal. I disconnected both sides swaybar and tried to rotate it up & out of the way for additional clearance without success. I see a few people have had issues at this point. I'm not following how they used a jack to resolve this. Any help appreciated.
Honda Civic 10th gen Spoon Springs Install DIY fuHAxFa
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
i forgot what i did. I think I jacked up the sway on the other side to make clearance
02SilverSiHB
Annapolis, MD
2019 FK8
do you have both sides off the ground? Or just this one side you are working on?
02SilverSiHB
Annapolis, MD
2019 FK8
edit: I mistook your pic for a different area...yeah, make sure both sides are up (as in both sides of the car on are stands)? I'm sure you did, as you mentioned you disconnected both sides...but just making sure. If one side is down it makes it difficult to move the other side.
spoonsportsusa
spoonsportsusa
Spoon.Official
Orange, CA
www.spoonusa.com
FK8 Civic Type R, FD2 Civic Type R, GK5 Fit RS, S2000
Did you remove the 2 bolts holding the other point of the lower control arm on step #7? It allows the arm to pivot out of the way for better access to that bolt you can't get out.
RStoR
NC
Yes, was able to wiggle it a bit more today and finally got it out. Thanks!
RStoR
NC
Thought I'd offer some tips to others who attempt this install themselves.
  • Lower Control Arm Bolt - The single forward bolt provide me and others some issues during removal. If you remove it prior to loosening the two bolt rear mount, it comes right out without issue.
Honda Civic 10th gen Spoon Springs Install DIY img_6029-
  • Lowering the Knuckle - The instructions state to slide the rear two bolt mount forward, which definitely helps, but you can gain additional drop by using a pry bar and raising the single bolt mount point during lowering. The control arm hits the subframe when lowering so by raising that pivot it provides more clearance.
  • Cutting Rear Bump Stop - There is no mention of this in this tread but the Spoon instructions state to cut 15mm off the rear, just like the front. You can pry up the shock dust boot from the bottom and push it up to expose the bump stop. Grab the lower portion of the bump stop and pull it down. This will allow easy access for cutting while still mounted.
  • Optional: Rear Upper Control Arm - I installed Eibach Adjustable Rear UCAs at the same time. The inner pivot bolts are difficult the access. I used a 17mm pass-thru wrench & socket with great success. There isn't much room and the thinner design of this wrench/socket allowed me to get it most of the way out easily. If you disconnect the UCA at the knuckle prior to this, you can move the arm around to take pressure off the bolt once it's backed about halfway out. This allowed me to unscrew it by hand the rest of the way out.
