- Mar 25, 2018
- 45
- 1,194
- 1,059
- Cesspool
- 2019 Civic Si
- Banned
- #241
so are you stating that the effects of a clutch not completely disengaging could present a rough or grind condition in just the 1-2 shift because the rpm drop quicker during that shift than any of the other upshifts?This part of your statement is true, all gears would be affected by a clutch issue. But there is a factor you are not considering here with your last sentence. There is more RPM drop between 1-2 than any other upshift. With each progressive gear the RPM drop becomes less and less, so less and less time is needed by the synchros to do their job.
Example with Type R numbers:
1st gear=3.625:1
2nd gear=2.115:1
3rd gear=1.529:1
So if you shift at 3625 RPM for an easy number, then the input shaft is doing 3625RPM while the output shaft is doing 1000 RPM.
When you shift into second, the output shaft, which is coupled directly to the wheels, maintains 1000 RPM, but the input shaft needs to slow down to match the new second gear ratio. That means when you slide the shift lever over and engage the cone of the synchro, it uses friction to slow down the input shaft to match the new second gear ratio. With this easy math that is 2115 RPM, resulting in an input shaft speed drop of:
3625 RPM-2115 RPM=1510 RPM drop.
Now if we take the engine to 3625 again (no more easy math) the input shaft is again at 3625 RPM but the output is now:
3625RPM/2.115=1714 RPM.
To shift into third, the input again has to be slowed by the synchro to match the third gear speed that goes with 1714 output shaft RPM. So input in third with output of 1714:
1714 RPMx1.529=2620 RPM
So for the 2-3 shift the synchros only had to slow down the 3625 RPM input speed to 2620 RPM, for a total drop of:
3625-2620=1005 RPM
In summary, the 1-2 shift requires an input shaft speed drop of 1510 RPM, while 2-3 requires only 1005 RPM. That means the synchros have to slow down the input shaft 50% more for the 1-2 shift that for the 2-3 shift. Since energy is velocity^2, the amount of energy dissipated by the synchros is a little more math-involved, but I quickly calculated it at 38% greater for the 1-2 than the 2-3. Someone feel free to verify that number, or any of my numbers for that matter. I did them quickly.
But regardless of the correct number, the point is there is more energy dissipated for 1-2 than for 2-3. Nothing happens instantaneously in a transmission, this includes the energy dissipation by the synchros. More energy dissipation requires more time for a given dissipation rate, so the 1-2 shift needs more time than the higher gears to do its job at a fixed dissipation rate. Or it needs a higher dissipation rate.
Going up into higher gears will see a continuing trend in speed drop and energy dissipation, with each successive change being smaller than the previous. So if you have a problem with the clutch disengagement time not being sufficient to allow the synchros to work, the problem will be the worst in lower gears, and show less trouble as you go into higher gears. Less engine drop results in less work by the synchro, less energy to dissipate, and less time required to perform such operation. And keep in mind that this function by the synchros is measured in milliseconds in high-performance applications.
So again, to stand behind my earlier statement, a small increase in clutch disengagement time COULD have a big effect in the perceived function of the transmission, depending on the exact nature of the problem within the system.
so that would imply that if you waited long enough between the 1-2 shift to let the rpm of the input shaft drop to the same as the 2-3 shift, the still partially disengaged clutch wouldnt cause a grind like it doesnt in the 2-3 shift?
