brokenEXTowner
Im having the same problem. I think it only takes the +6 psi only. Cus i uploaded the setting to turn off vsa along with carb compliant +6 psi just to test it. It uploaded but vsa was not turned off when i started the car.Another question since this is a carb unit, I save the changes to a new calibration file after I put a large number in where 124 mph was. It won't let me upload that file with an error message that it's not carb compliant.
I did do an upload after just changing the parameters and it worked but not sure if it took the change or just uploaded the same base map?
Thanks!
