UFO CTR
- Oct 12, 2016
- 22
- 2,530
- 1,877
- San Frrancisco, CA
- 2017 CTR#1348
they said $20/wheel
Sorry wrong thread...
Planning on lowering? Would you modify your fenders if you did lower?18x9.5 +35 Mag Blue Volk CE28SL with 255/40/18 Conti DWS06 on stock suspension
You may find that you’ll rub once you lower. I’m going to be running 18x9.5+38 and I’ve been told it would rub if I lower it on 265/35 tires. Wheels should be here soon so we’ll see...Not anytime soon but eventually I will, probably won't mod the fenders either
The guy who sold me the wheels is running same tire size and he's lowered on Eibachs, he said he doesn't rub unless he hits a pretty harsh bumpYou may find that you’ll rub once you lower. I’m going to be running 18x9.5+38 and I’ve been told it would rub if I lower it on 265/35 tires. Wheels should be here soon so we’ll see...
I know this was posted awhile ago but I love these wheels and want order them. I live in America and dont see any shops carrying Fast Wheels. Do you know where I can order them from? You have any issues with them so far and do I need a certain style lug or TPMS with these. Thanks in advance.Fast wheels FC04, 19lbs
18x9 +40
RE71R
245/40/18
My track setup, did 3 DE track days with them last year, love the handling with them on track.
Don't know anything about Fast Wheels but see in your signature you have a sport hatchback. Wheels from a Type R will not fit your vehicle. Also in your vehicle there isn't any TPMS sensor. The low tire pressure is determined by variations in the wheel speed.I know this was posted awhile ago but I love these wheels and want order them. I live in America and dont see any shops carrying Fast Wheels. Do you know where I can order them from? You have any issues with them so far and do I need a certain style lug or TPMS with these. Thanks in advance.
Is this still stock height/suspension?
Acura NSX F Wheel Set
Diameter: 19”
Width: 8.5”
Offset: +55mm
Weight: 18.9 lbs/ea (after powdercoat application)
Hub: Requires hubcentric ring (70.1mm – 64.1mm)
Tires: Michelin Pilot Sport 4S (245/35zr19)
Notes: Wheels were chem-stripped to raw material, then powdercoated in gloss black to match the OEM centercaps.
I have attached my wheel upgrade analysis documenting fit, cost, and projected savings based on available tire compounds in the 19” range.
I know the rims are different bolt pattern and sizing but fast wheels makes the same style rim in 114.3 pattern and 18 x 9 which will fit. I only found one website that sells them and its not a know website to me so makes me leery. (1010tires ) thank you for letting me know about the tpms. I didnt even know they did such a thing which is good because i hate those things i ve always had bad luck with them leaking and breaking.Don't know anything about Fast Wheels but see in your signature you have a sport hatchback. Wheels from a Type R will not fit your vehicle. Also in your vehicle there isn't any TPMS sensor. The low tire pressure is determined by variations in the wheel speed.
1010tires is a legit site.I know the rims are different bolt pattern and sizing but fast wheels makes the same style rim in 114.3 pattern and 18 x 9 which will fit. I only found one website that sells them and its not a know website to me so makes me leery. (1010tires ) thank you for letting me know about the tpms. I didnt even know they did such a thing which is good because i hate those things i ve always had bad luck with them leaking and breaking.
The actual NSX rims are forged I believe. That is an important feature.1010tires is a legit site.
1010 Tires is definitely legit. It’s a Canadian tire change and fairly large in central/eastern Canada. Fast wheels are fairly reputable here North of the border here as well.I know the rims are different bolt pattern and sizing but fast wheels makes the same style rim in 114.3 pattern and 18 x 9 which will fit. I only found one website that sells them and its not a know website to me so makes me leery. (1010tires ) thank you for letting me know about the tpms. I didnt even know they did such a thing which is good because i hate those things i ve always had bad luck with them leaking and breaking.
