Spoon Springs Install DIY
spoonsportsusa
Spoon.Official
Orange, CA
www.spoonusa.com
FK8 Civic Type R, FD2 Civic Type R, GK5 Fit RS, S2000
We've swapped the springs out a few times already so we just wanted to share the method that is quickest for us. Total time for the front is about 1 hour and rear is 10 minutes.
Front
1. Remove undertray (to access lower arm bolts connected to the subframe)
2. Disconnect the swaybar end link side that attached to the strut on BOTH sides of the car by removing the nut. This prevents the suspension from binding when dropping the strut. Pull the link out of the strut.
3. Disconnect damper electrical connector (pry the tab up in the gap).
4. Remove the bracket holding the connector line and brake line.
5. Disconnect ride height sensor bracket that connects to the lower arm.
Honda Civic 10th gen Spoon Springs Install DIY IMG_6002-2
6. Disconnect the front suspension link. (behind plastic brake air guide)
7. Remove the bolts that hold the front lower arm to the subframe. (3 bolts)
8. Remove the two pinch bolts holding the bottom of the strut
9. Remove the nuts on the top of the strut to the body.
10. At this time you can pull off the locating tab in order to get some extra camber in the front.
11. Pull the lower arm out of subframe and be careful not to pull the driveshaft out. At this time the whole assembly should be loose and provide enough clearance to wiggle the strut out. (Sorry no proper picture here)
12. Use spring compressors to compress the spring and take the top nut off holding the hat.
13. Cut off one section the bump stop.
14. Transfer over the rubber bases and take note of how it slots onto the spring and bottom perch.
15. Compress the spring and install it on the strut. Make sure all the rubber pieces are correctly positioned as they tend to shift during assembly.
16. Reinstall onto the car in reverse order.
Rear
1. Remove the bolt holding the swaybar link to the lower arm.
2. Remove the bolt holding the lower arm to the knuckle.
3. Pull the lower arm down and the spring should fall out.
4. Transfer over the rubber perches and take make sure the tabs are aligned when reinstalling.
5. Put a floor jack under the lower arm and raise it until the bolt holes line up.
6. Reinstall the two bolts.
Las Vegas
Great write up!
Hondanickx
Belgium
Are those Front springs also the stock Type-r ones?Looks like those are progressive from the factory already .
spoonsportsusa
spoonsportsusa
Spoon.Official
Orange, CA
www.spoonusa.com
That’s a great write-up for tech-docs!
Would like to see how the ride hidth settles at; pictures of the FK8 after the installation?
Spoon Progressive Springs
Titan 7 T-S5 19x9.5+45
Yokohama Advan AD08R 265/30-19
neveronline
Clayton NC
Current '19 CW CTR #23856 & '18 Accord 2.0T Previous - 2015 WRX, 1999 SI, '04 S2000, '08 Evo X, '10 SI sedan, '11 Fit Sport, '11 WRX, '13 ILX
Thank you for the write up Spoon Sports / Go Tuning!:thumbsup:
spoonsportsusa
spoonsportsusa
Spoon.Official
Orange, CA
www.spoonusa.com
looks like spoon springs=more saggy butt
Eibach and Spoon are the same height down to 1/16th-inch. Swift would be lower than both Spoon and Eibach and also stiffer. So in essence the drop is the same for Eibach and Spoon
spoonsportsusa
spoonsportsusa
Spoon.Official
Orange, CA
www.spoonusa.com
How does it ride / handle compared to the Eibachs? Thanks.
Spoon are more compliant than Eibach but doesn't sacrifice roll resistance. Through the corners the Spoon springs do a better job absorbing bumps and stays well planted. Eibach are a little stiffer than Spoon but you get sharper steering response but the tradeoff is a little harsher ride.
02SilverSiHB
Annapolis, MD
2019 FK8
Eibach and Spoon are the same height. Front is identical down to 1/16th-inch. The Spoon rear is a tiny bit lower than Eibach making the wheel gaps equal front and rear whereas Eibach had a slightly larger gap in the rear than the front. Swift would be lower than both Spoon and Eibach and also stiffer. I don't think you could see a 1/16" difference with the eye so in essence the drop is the same for Eibach and Spoon
true, I noticed it with prokit also...reminds me of the days of my 2005 STi when it was reallllly saggy in the rear :D
