PRL Motorsports Type-R Front Pipe
elusiveaura
Tennessee
2020 CW CTR - 2020 Acura RDX A-Spec
Do the downpipes on the R have as much risk of breaking the bolts/studs like they were breaking on the SI when removing the stock downpipe?
17siturb0
U.S North east
2017 civic si sedan, 2006 civic si coupe
Yes, Honda used cheap ones as far as the stock bolts and studs, get higher grade ones and you will not run into anymore problems, highly recommend.
PRL Motorsports
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
Sadly, we were faced with a few small obstacles while machining the upper castings. :( There was a software error which affected a stop which caused a crash in our 5-axis. All is fixed now, though, our machine is back up and will start running again Monday. Rest assured that this was only a minor setback and orders will begin shipping shortly after these are done being machined. Our new jigs should make welding a breeze! :) We apologize for the delay, it's difficult to update every media outlet immediately.
Yes, the downpipe installation still risks the possibility of breaking studs/nuts like the 1.5T Civics. Honda uses locking stainless nuts from the factory which is great for permanent installs, but not so much when planning to remove. :fear: We typically have luck with penetrating lube and a heat-inductor.
We do not recommend wrapping exhaust pieces, as the wrap tends to retain heat in the pipe/tubing instead of allowing it to escape. Though our products are back-purged and the castings are extremely beefy, this increases the risk of weld/material failure. The factory heat shield should be enough, or we recommend looking into a true ceramic coating if you're extremely concerned.
jpmelfi
New Jersey
CTR #706, 07 S2k
@PRL Motorsports Great information in regards to the wrapping! Do you feel that the higher exhaust temperatures for using a turbo blanket will cause any issues with your catted down pipe?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
We do not foresee any issues with a turbo blanket. :)
Maximum6
Las Vegas
S2000 2005, Type R 2019
What about the front pipe? Don’t wrap that either or does oem heat shield fit the front pipe?
Tim818
King Of The ‘Ring
Texas
2006 Civic EX, 2018 CTR
Hopefully the downpipes start shipping out tomorrow...
therealdarkknight
Christian
Glendale, AZ
2017 Civic Type R
Just got a shipping notification! Should be here 7/25. So excited, now I can finally put my turbo blanket on.
Tim818
King Of The ‘Ring
Texas
I kinda regret changing my order now lol, I probably won't get mine until next month.
