New to this - just flashed (next steps)
Dfine06
New Jersey
I just flashed for the first time with the stage 2 dual tune (eco button) is factory setting. Off is 21 psi(?).
This is my first time doing this, was that the right choice? I liked it because of the option to go stock at the button push.
Also I am getting an intake next week, do I need to reflash? How does that work after the install of the intake.
I’m very new and any more info would help. I’ve read a TON on this forum, ktuner website, videos etc. it’s almost overwhelming as opposed to just asking outright in my own post for help.
Thanks!
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
If you were looking for stage 2 power, that's the right choice! The dual target options are great.
Depending which intake you get tuning may be suggested.
Dfine06
New Jersey
@KTuner how much hp gain average would you say added without any other mods running just this tune?
jakabony
Jake
Pittsburgh PA
www.facebook.com
2017 Honda Civic Si, 2019 Honda CR-V EX-L, 2017 Subaru Forester
The issue won’t be the engine, it will be the clutch or CVT over time. Even by creating a broader, flatter torque curve, it still will stress the clutch and CVT. It’s inevitable.
Dfine06
New Jersey
I feel like it takes the turbo it a little longer to kick in, then when it does it rockets. Does this make sense? Am I just imagining it?
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
Yes, this is true if you are going max throttle around 2000rpm. This will also put the most stress on your transmission. I am on a 21-22 psi tune and prefer to downshift when I need / want to accelerate hard, and floor at least after 3000rpm (I try to get past 3500 to be honest). Then the turbo will spool super fast (quick settings will help on that) and maximum acceleration is available almost instantly.
Dfine06
New Jersey
@KTuner I am adding an injen Sri. Should I reflash. Or make any adjustments?
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Consult with a tuner for fine tuning. The injen for non-Si we've seen throw fueling off anywhere from 7-15%.
