J's Racing Shift Boot Collar Install?
TranceFC1
Inland Empire, CA
2017 Civic EX-T Manual
Anyone install one of these yet. Trying to install it on my ext to get rid of the stupid ring that comes stock but can't find much online about it
ebatr24
Oregon
I've got one
ebatr24
Oregon
Here is a pic, not super close up tho. Don't mind how dirty it is, lots of dust gets in with the windows down and the weather has been great. Cleaning it up today. :)
Honda Civic 10th gen J's Racing Shift Boot Collar Install? 20180609_144958~2
TranceFC1
TranceFC1
Inland Empire, CA
I'm guessing you have to remove the boot flip it inside out cut off whatevers holding the oem ring then put the new collar and put that elastic band over it to secure it and put it back on and tighten the bolts for the level?
ebatr24
Oregon
Yup, cut off the zip tie and then install the new one using the little rubber band they give you. The sucky part is tighting the hex key bolts with a little allen key. Gotta do them evenly so it is centered correctly, my old know let you see the J's racing logo more but I still love it.
TranceFC1
TranceFC1
Inland Empire, CA
I ordered the type r shift boot console for my ext. I'll take some pics of the installation for others to check out since there isint much on it on here
vader2k
Darkside rider & Senior member
Alonzo-Ignacio
Downtown Sacramento, CA
17 Civic Type R. #433 (EPB). 07 Civic LX (TW)
Looks great! So what do you remove first, to remove the shift boot leather? I've pressed and prodded the exterior casing but cant manage removal. Any suggestions?
ebatr24
Oregon
Sorry man, forgot about this thread. Hope you got it, if not you pull the plastics on the sides of the radio up so you can unscrew the center console piece with the sport, brake and brake hold buttons. You can then pop this off, unclip the buttons and work on removing the stock collar to install the new one. After that you put it back and adjust it till you're happy with it.
vader2k
Alonzo-Ignacio
Thank you for the information, I was able to get installed. Your feedback was perfect!
Ctdc2
Clayton
Honolulu
2018 civic type r
how did you get the lock collar off? Mine just gets stuck.
ebatr24
Oregon
You mean the collar that holds the boot? Did you yank the boot down so you can turn it with a wrench?
Ctdc2
Clayton
Honolulu
2018 civic type r
Yes, found out my locknut collar is cross threaded
