jmark
- Mark
- Apr 4, 2018
- 9
- 348
- 178
- Greer SC
- 1997 NSX-T & 2021 Civic Type R LE USA-029
Wheels look great. Any rubbing? OEM CTR centercaps fit correct? Rims are hub centric correct? Tire size 245 or 255/35/19 opens up a lot of tire options too. Thanks.today was great weather and had finally installed my @Mishimoto intake so wanted to have an excuse to drive...plus had to do dinner. put on about 50 miles for the first time with the new nsx wheels and 245/35/19 potenza re-71r tires.
wow...just wow! dammit i love the wheels and tires! still new so a little squirmy but on the way home i took a cloverleaf at about 75 mph. sticky...love it. i do not need 265 or 275 width tires on the streets to smile big smiles.
now with stickier tires the car will pitch a little bit more - meaning your feet stick more while you go around the corner yet your body continues to have momentum toward the outside of the turn ala pitches. it's basic physics. this why for you guys throwing on wider and/or stickier tires and getting more lateral grip in the corners - you WILL notice the car roll a bit more. therefore, tighter suspensions ala stiffer sway bar(s) is required to counter the stickier or more lateral grip tires. if you don't believe me, ask the pro autoxers and trackers. everything works in unison...make a change in one thing and will impact another until you counter it. simple physics...
btw there is ZERO change to the stock zero torque steer front end design...that was my goal all along and why the wheels at 19x8.5 +55mm et work!
